1971Demon
1971Demon
I have,a 1971,340 demon having, a,problem gas gauge temp gauge keep on going up and down replaced and checked everything were is,voltage limiter location on rally gauges and would that cause this,problem THANK You
Pull the cluster and test it on the bench.... If that turns out good.... You hooked something up and are sharing the same common wire.... You just going to have to chas it, the way I read it...
