50 plymouth suburban
Hello and Hello,
i would like to change out the brakes on her and would like to go disk all the way around. will a cordoba rear end work, and i know that there are plenty of kits for the front. would also like to change out the trans to an automatic. Suggestions would be appreciated.
thank you and glad Im here
My personal opinion is disks on the rear are a big headache. A nice disk swap on the front is a great idea! Trans? What motor are you planing ? Small block ? I would think about an overdrive 518/42r from early 90's Van/truck
Very few Chrysler's had rear disks,
Engine
Its the stock Flat Head Six, Im keeping it. for the rear end, i was thinking the cordoba or laberon, Didn't they have disk in the back. I would do a complete axle swap. going to lower it and just drive.
If you are keeping the flathead 6 switching to an auto will be tough Unless you can fine an adapter or someone to make one ! Not a cheap undertaking.. A complete swap would be in order motor,trans and rear end , probably cheaper too..
Try contacting www.wilcap.com for adapter.
I have read suggestions to use a 350, I would think a 2004R OD would be better it has a 1st gear ration of about 3.08
dz!
06-01-2010 06:12 PM
