69 bird
Old Oct 24, 2010 | 08:46 PM
mopar 69's Avatar
69 bird
hello to anyones advice, i have what was told to be a 69 roadrunner, the vin# and fender plate is missing, is there any way to tell if its a true rrunner? only #s i can find are on the trunk lip, they only show production #s thanks
Old Oct 25, 2010 | 01:23 AM
BuckNeccid's Avatar
In '69 they should match the serial number. The last year they showed production number was '68. I hope it's just wanting a real road runner and not cause you paid road runner price for a satellite. If it's matching number, you will have the serial number stamped into the block just above the oil pan rail on the passenger side, and very close to the same location on the tranny. Easier than that, before you start crawling under the car, it should have a 383, and there should be an E 383 stamped on the horizontal with the ground pad in front of the passenger side head, on the block.
Old Oct 25, 2010 | 02:29 AM
Old Oct 25, 2010 | 04:51 AM
rr69half6bbl's Avatar
Did you get a title w/ the car or just a bill of sale? is the int. still intact . pull the back seat bottom and see if the build sheets still there. If not there. try the front seats. on bottoms.
Old Oct 25, 2010 | 12:40 PM
mopar 69's Avatar
it has no engine, just a rolling shell i bought for 200.00 just hopeing it is a bird
Old Oct 27, 2010 | 06:15 PM
If the numbers are still on the rad support, drivers side, then you can copy them down and contact galen gavier at gts.com and for a fee you can give him the vin numbers and he has build lists, he may be able to confirm what it is.
castillo70
Jun 6, 2012 08:01 PM
Bradster
Dec 10, 2011 05:22 PM
mopardrt
Aug 1, 2010 12:24 PM
Coronet1970RTguy
Jan 3, 2010 02:46 PM
runninbird
Dec 30, 2007 04:19 PM
