‘74 Valiant starts then dies in run
Old May 25, 2020 | 08:47 PM
Katgerdy's Avatar
I have a ‘74 Valiant Scamp with a 318. It starts then dies soon as you let go of start position. I replaced the pcv valve today and it stayed running. Started back drove to get gas. Started later went to Walmart and It died while idling in park. It started back on second try and made it home. Now it is doing the exact same thing. It has a new Ballast resistor, and new voltage regulator, coil, and battery. Had quite a bit of wiring issues since I’ve had her eight months. Any help would be great. I’m not a mechanic for sure just learning about my car so I need some diagnostic advice.
Thank You so much
Old May 26, 2020 | 02:07 PM
Check and replace any cracked Fuel and Vacuum hoses.. Replace the fuel filter, Check it to see if any rust or crud comes out of the filter?
berjkara
Mar 26, 2020 09:20 AM
Ryngus
May 22, 2017 02:02 PM
Mrpyro187
Nov 13, 2012 05:26 PM
miserablebob
Jul 28, 2011 10:46 PM
Tom Wright
Mar 2, 2011 03:12 PM
