Compression 277
Old Jun 17, 2022 | 01:19 PM
Oldbelv's Avatar
Compression 277
Hi. I have 56 Plymouth with 277. The compression is 105-115. Low but consistent across. The engine doesn’t smoke and oil is clean. It idles great but when I hit the gas and put a load it sputters. I’m trying different things like pertronix ignition and wires. But my question is should the engine run well with this compression? I think it should. I’m trying to diagnose. Thank you.
Old Jun 17, 2022 | 01:28 PM
Today’s fuel issues might have found you, a carb kit and a couple degrees of timing should fix the old girl up.
Old Jun 17, 2022 | 01:57 PM
Oldbelv's Avatar
Fuel
I was thinking about the gas. Should I advance or retard the timing? I never heard that idea before. But it’s intriguing.
Old Jun 18, 2022 | 07:00 AM
It sounds like it needs a couple of degrees of timing advance but put a light on it and see where it’s at.
flashman
Aug 10, 2018 05:20 AM
kcunningham1999
May 4, 2017 05:02 PM
1973 plymouth satellite
Dec 14, 2015 02:36 PM
moparca
Jul 26, 2011 12:39 AM
dmont
Jun 27, 2010 07:08 PM
