flex plate
Old 04-03-2013, 04:18 PM
goldenpistol's Avatar
flex plate
hello every body i am new to this forum need help
i bought new converter boss hog night stalker part number APE-54092
when i want to replace the stock converter the flex plate holes for bolts not match i am looking for flex plate to fit the new converter my car challenger 71 with 440 rb engine and 727 auto trans
Thnaks for every body
Old 04-03-2013, 04:27 PM
Gorts 5th's Avatar
Smile
welcome.
i am not familiar with the converter some one here may be
the flex plate bolt holes are indexed they have a pacific position to line up try spinning the converter and try aligning the bolt holes this is kinda time consuming but if you didn't mark the flex plate and torque converter before you reinstalled it you got to do this
the oem converters and flexplate have a mark on them usually a circle to help you line up the two.
this brings us to the next, what if the converter is not marked or if it requires a special flexplate? what do the converter tec's say about this have you talked with them?
goldenpistol (04-18-2013)
Old 04-03-2013, 04:33 PM
thanks i talked with the tec in summit racing he said i will call the boss hog night to see what flex palte match with the part ape-54092 the stock flex plate has 6 hole in middle and fit but the for end bolts not match sorry for my language im from kuwait country from middle east
Old 04-03-2013, 05:38 PM
You just need the correct flex plate Mopar used to offer a HD one used the larger bolts. Or you could re drill them
Old 04-03-2013, 06:39 PM
The crank holes in the center only go one way as do the four that attach the flex plate to the torque convertor.
Old 04-04-2013, 05:12 AM
62Furious's Avatar
Mopar used 2 converters a 10 inch and 11 inch, they also were internaly and externaly ballanced, If your old tork converter has weights wellded by one of the bolt holes it is externaly balanced. If your engine is a 71 all you will probebly need is a flex plate for a 10 inch converter, if your engine is externaly ballanced you will have to get the flex plate through summit or jeggs or after market and request externaly ballanced engine
Old 04-04-2013, 08:46 AM
.............and to make things more complicated my understanding is that the later magmum flex plates were NOT offset which means that if you have a newer symmetrical converter bolt pattern and the older LA "offset" pattern flex, they won't fit, either. In other words you might have the wrong converter.
The original converter/ flex combo had index marks to help you line them up. My foggy memory wants to say that on some, the drain plug replaced the index mark on the converter
Old 04-04-2013, 03:41 PM
Thanks for every body i just found the wright one in the junkyard the stock flex plate was small 8 inch the 10 inch fit the new converter
Thanks again for all
Old 04-09-2013, 05:41 AM
rickyr's Avatar
goldenpistol (04-09-2013)
Old 04-18-2013, 05:25 PM
Thanks my engine year 78 how should i know if i need internal or external flex plate the cranck is stock cast i found flex palte at junk yard and its fit the new converter but when i install it i fell vibration is it from the flex plate or somthing else , i contact summit the advice me with this p/n TCI-145700 and i found one from kmj performance p/n kmj FP440L
witch one is match
Thnaks again
Old 04-18-2013, 07:58 PM
It may be the wrong converter as far as balance goes..
Old 04-18-2013, 10:50 PM
PURPLE HORONET's Avatar
Agree their is a internal balance and a external balance converter,, The best way to tell is looking at the balancer,, external had a big one internal had a small one.. If its a factory cast crank 99% of the time its external..
I can post a pic of the small balancer if needed
Old 04-19-2013, 04:01 PM
yeh please post pic
Thanks
Old 04-21-2013, 12:46 AM
The red small one is internal ballance,, the big one is external
goldenpistol (04-22-2013)
Old 04-22-2013, 04:18 AM
yes you are right on my car the big one so its external
Thank you very much for your help
Old 04-22-2013, 03:23 PM
mickelsdogs's Avatar
Unhappy car show this weekend So. Minn. 4-27-2013
New here 2 site not wantin 2 get booted 1 st post PLEASE???? Did U have 2 shovel toy box door 2 get it open today ??? 4?22? 2013 Its april all my old street "GRAFFITY NEEDS 2 B RENUED" IN STEREO R do I say PARALELL Boy I hate it when my MOPARS wana B out n i wont do them like that. My dog is lovin the APRIL SNOW!!!!!!!! Local radio station guy been doin car show 40 years plus, check that out
Old 04-22-2013, 07:57 PM
ics:
68GTX440
10-01-2013 06:25 PM
willysman69
12-23-2011 01:25 PM
bentman
01-18-2011 06:59 PM
mytracy
12-29-2010 08:20 PM
mikeynags
05-03-2010 06:45 AM
Quick Reply: flex plate
