Help needed with 1961 Chrysler V8 6.3 Engine oil seal
Old Aug 14, 2019 | 07:47 AM
Malcolm's Avatar
Hi
I am hoping one of your members can help me. I have had the above engine rebuilt and we have a seal left over from an engine gasket set manufactured by FEL-Pro, part number FS 7891PT, the seal has National Mexico 3103 stamped on the rubber. The dimensions are OD 3/3/16" (80mm) ID 2 1/2" (55mm) Depth 5/8" (15mm). Is it possible that this gasket set is supplied with 2 alternate seals, although the packaging does not list alternatives?
Or has the engine builder left this seal out by mistake (unfortunately the engine was rebuilt approx 2 years ago and no-one can remember). Does anyone have any idea where this seal fits?
I also require a thermostat housing for the engine
Any help gratefully received
Cheers, Malcolm
Old Aug 14, 2019 | 08:26 AM
Back then there was a raised block 383 and a low deck 383 or a rb and a b block, they both had different crank journal sizes so two different seal sets. Both seals would have been in a kit.
Old Aug 14, 2019 | 08:28 AM
Also welcome to the forum!
Old Aug 15, 2019 | 07:06 AM
I Agree on the seal issue..... Also Welcome to the site...… The Thermostat Housing you can get online or threw your local Napa store still....
CMVALIANT1979
Nov 21, 2018 02:38 PM
kcunningham1999
May 4, 2017 05:02 PM
Durango-Tango
Feb 4, 2013 02:37 AM
kdykes
May 13, 2012 04:28 AM
jerzjer
Apr 29, 2011 03:02 PM
