horse power
Old Mar 9, 2017 | 04:14 PM
78dodgepickup's Avatar
horse power
Hello everyone my first time here. Can anyone tell me how much horse power u need to run 2 500 carbs on a 440
Old Mar 9, 2017 | 07:09 PM
375HP....
Just my 2 cents
Welcome to the site....
Old Mar 10, 2017 | 05:27 AM
Need 1000 cfm, or want a cool two carb setup for your 440, that is the question..........
..hmmmm
Old Mar 10, 2017 | 06:20 AM
Chryslers "Six Pack" of 1200 cfm advertised at 390 HP. Center carb only and outside carbs on demand based on engine vacuum, load.
Two 4 barrels would depend on progressive or vacuum opening with camshaft "size" to make an efficient system. Manifold height will also be a factor to consider.
Old Mar 10, 2017 | 08:04 AM
You have a very open question there , what carbs and manafold are you thinking about?
Old Mar 10, 2017 | 01:33 PM
Old Mar 10, 2017 | 01:43 PM
cam,intake and carbs
Old Mar 10, 2017 | 01:47 PM
The cam is a284-484 and I'm thinking bout a Edlebrock 5440 intake and Edlebrock 500 carbs
Old Mar 10, 2017 | 01:57 PM
How much compression do you have?
Old Mar 10, 2017 | 02:05 PM
I think it was on engine masters on the Hot Rod utube chanel they did that setup on a sbc, you might have a look. If I remember it made good power but has been awhile.
Old Mar 10, 2017 | 02:07 PM
What is your combo ?? 284/484 Ah a purple shaft cam.. It needs a 2800 stall converter and should have a min 3.55 gear
Old Mar 10, 2017 | 05:26 PM
horse power
Compression is 11.5 to 1 I'm using 3500 stahl with 3:55 gear
Old Mar 10, 2017 | 05:27 PM
horse power
Compression is 11.5 to 1 I'm using 3500 stahl with 3:55 gear im going to change to 3:90
Old Mar 10, 2017 | 07:37 PM
What are you using for heads?
Old Mar 12, 2017 | 05:36 PM
heads
Heads r 452s but im going to go to 906s
Old Mar 13, 2017 | 02:06 PM
The 452s make slightly more power than the 906s with cam lifts below .560 lift. With the compression ratio and the converter you have a larger cam like the .557 mechanical or the .509 if you wanted to stay with hydraulic. Ive got a 9.5 motor that makes 520 whith the .557 cam and 452 heads. Heads have been pocket ported and 2.14/1.81s fitted. Very straight forward build.
Just curious about what you're looking at for fuel?
Old Mar 13, 2017 | 06:50 PM
Fuel
I've been running 91 octane cause it's hard to find anything better where I live but my truck runs pretty good right now on 91 but right now I'm running a 750 edelbrock
moe7404
Mar 11, 2017 11:46 AM
ChrisG
Oct 5, 2012 11:43 AM
fletchy38
Aug 5, 2012 06:14 PM
moparmadness75
Jun 1, 2012 01:35 PM
Moparknighthawk
Nov 8, 2008 04:43 AM
