360 build how much horse?
Old May 31, 2012 | 09:06 AM
moparmadness75's Avatar
Hey i have a 360 im building and im wondering what kind of power ill get with these mods
edelbrock 650 performer carb
edelbrock performer intake mani.
Slightly machined 360 heads..bigger valves 480 lift
cam i cant remember what type
headers
Msd ignition
Just a ballpark answer would be great.
Old May 31, 2012 | 11:52 AM
MrOldart2U's Avatar
Not gonna even try to guess with the lack of info given... Cam specs alone can make a significant difference in power. Stock 360's start about 250hp.
Old May 31, 2012 | 12:12 PM
ill have more info about everything later to help but thanks that will help to
Old Jun 1, 2012 | 02:29 AM
Depending on the year the 360 you are building was made, that number could be higher or lower too. I've only seen 155-220 HP in some spec listings while torque has been from 235-285 ft/lb..
What heads are you using? Can you post up the casting numbers from teh block and heads? Some people on here can run the number and let you know what you are at least starting at with a stock motor.
Old Jun 1, 2012 | 01:18 PM
once i get them pulled off i can get the #s
Old Jun 1, 2012 | 01:35 PM
Casting numbers on teh block should be on the passenger side. As far as the heads go, I think they are where the rockers are under the valve covers.
moe7404
Mar 11, 2017 11:46 AM
ChrisG
Oct 5, 2012 11:43 AM
fletchy38
Aug 5, 2012 06:14 PM
Buffalojoe426
May 14, 2010 03:42 AM
Moparknighthawk
Nov 8, 2008 04:43 AM
