Ignition.Key turns on but won't stay on
Old Apr 20, 2020 | 11:57 AM
Walshkid's Avatar
1967 Charger.turn key on car starts.Release key and car turns off.Hold key in on position and car runs.Soon as you let go of key car turns off.If you hold key in on position car keeps running.but let go of key car turns off.please help thx very much
Old Apr 21, 2020 | 08:33 AM
Check the Ballast Resistor
Old Apr 22, 2020 | 10:18 AM
Walshkid's Avatar
Ballast resistor
Ballast resistor was replaced and bam ,problem corrected.thx very much.you rock!!
Old Apr 22, 2020 | 10:36 AM
Mopar on !!!!! Cheers
Old May 14, 2020 | 05:29 PM
Walshkid's Avatar
Hi Racer Hog
I got another situation.My column shifter engages in all gears except park.When I engage into Park,it is in neutral.please help.thx Tony
Old May 15, 2020 | 02:19 PM
Coulum Shift car ? Or Counsel ??????
Old May 15, 2020 | 07:46 PM
Walshkid's Avatar
Column shifter as stated thx
The column shifter as mentioned pls n thx
Old May 16, 2020 | 06:16 AM
Check all the shift linkage Bushings !!!!
If those are all good. Unhook the linkage from the trans lever and see if it will go into park? If it does, it's a linkage issue. If it does not, then it is something inside the transmission...
berjkara
Mar 26, 2020 09:20 AM
383bigbb
Jul 9, 2019 02:50 PM
Law Shurmen
Jun 3, 2019 07:08 PM
69ChryslerNewportCustom
Jan 16, 2018 05:44 AM
moparca
Jul 26, 2011 12:39 AM
