swapping engines
Old 09-12-2012 | 11:31 PM
Mudge1's Avatar
swapping engines
I have 1998 dodge durango with a 5.2 (318), if i where to go to the 5.7 (360), would the 360 bolt up to my transmission?
Old 09-13-2012 | 09:15 AM
Welcome aboard.
Old 09-13-2012 | 09:18 AM
Yes it will bolt up. , Need to change the flex plate or maybe the converter for balance factor what trans do you have ? If you have the A500 version- light duty ? it may not last long behind a 360
Old 09-13-2012 | 10:30 AM
78doubleR's Avatar
Just a small correction... 5.9 is a 360... 5.7 (354ci) is the HEMI.
Old 09-13-2012 | 06:43 PM
Welcome to the forum.... Be sure to check out the Mopar of the Month contest... See the sticky for the simple rules and then you can help choose the monthly winner....
Old 09-14-2012 | 05:48 PM
rickyr's Avatar
Old 09-14-2012 | 11:07 PM
challenger's Avatar
Welcome
Old 09-15-2012 | 09:44 AM
Are you looking to install a 5.9L/360 or a 5.7L/354?
If a 360, you'll want to swap in the PCM as well.
Tom T2
08-23-2015 08:21 PM
MoparMan76
01-09-2011 10:43 PM
craveman
04-12-2009 04:56 PM
bighammer
04-11-2009 12:05 AM
71RR08
11-25-2008 06:40 PM
