Temperature sending unit
Old Jun 30, 2021 | 05:32 AM
ole55dodge's Avatar
Unhappy Temperature sending unit
Converted my 1955 Dodge Custom Royal to 12 volt system. The temperature gauge on the dash is reading very hot although the actual temperature is about 185 degrees. At this temperature the gauge should read in the middle. Will the gauge work on 12 volts without a resistor? The gauge is currently on a resistor to lower it to 6 volts but I wonder if this is affecting the gauge. The sending unit is advertised for both a 1955 and 1956 Dodge which I would think means it will work on a 12 volt system since the 1956 Dodge was 12 volt. Any ideas appreciated.
Old Jul 2, 2021 | 07:36 AM
Most if not all mechanical gage's in a dash are 6 volt, the 12 volt cars used a resistor to drop the voltage at the gage.
so if you have an old dash laying around or you go to a parts store it shouldn't be a problem coming up with something that works.
ole55dodge
Mar 6, 2021 09:30 AM
Krops
Aug 3, 2018 06:06 PM
72cuda
Aug 30, 2013 08:48 AM
mikeynags
Jun 16, 2009 06:31 PM
Dave
May 7, 2009 05:39 PM
