Vacuum problems satellite.
Old Jan 13, 2014 | 09:31 PM
Deco Vegas's Avatar
Hi I've got some serious vacuum problems with my 74 satellite 360.I had a mechanic rebuild carb and do a heap of wiring after a engine fire did a bit of damage.When he hooked it all up he left a few vacuum hoses of, I can't seem to work it all out or find some diagrams out there to hook them up.Of course in Australia there are none of these to compare with.Any help would be much appreciated.Thanks Tony
Old Jan 14, 2014 | 02:09 AM
Myraman's Avatar
Not sure if these will help...
This is what I have. May apply to your situation may not. Let's hope so. If not, this is a great place and hopefully someone else will jump in..
I will also post 2 schematics of the complete wiring diagram just in case..
Its only going to let me do a couple at a time for some reason.. So..
Old Jan 14, 2014 | 02:13 AM
Myraman's Avatar
One at a time..
Yet another..
Old Jan 14, 2014 | 02:14 AM
Myraman's Avatar
One more..
Old Jan 14, 2014 | 02:15 AM
Myraman's Avatar
Only 4 more..
Old Jan 14, 2014 | 02:16 AM
Myraman's Avatar
Wow!
Old Jan 14, 2014 | 02:17 AM
Myraman's Avatar
Almost
Old Jan 14, 2014 | 02:18 AM
Myraman's Avatar
Last one I hope
Old Jan 14, 2014 | 02:21 AM
Myraman's Avatar
Ok not last one. Here's wiring schematics. Maybe it will let me do bot at same time..but I doubt it
Old Jan 14, 2014 | 02:23 AM
Myraman's Avatar
Apparently not. This is it, all I got.. Lol
Hope it helps. Good luck
Old Jan 14, 2014 | 03:59 AM
Mr.4spd's Avatar
If I was a betting man I would say the charcoal canister went up in smoke and was not replaced. This would account for a handful of hoses...
Old Jan 14, 2014 | 05:32 AM
Archer's Avatar
Deco -
What carb do you have?
Engine stock or modified?
It's really easy to over think this.
There are a limited number of carb/manifold vac ports to deal with.
Have you taken a vacuum reading, what does the needle on the gauge do and what happens as you increase throttle pressure?
Old Jan 14, 2014 | 04:41 PM
Deco Vegas's Avatar
Thank you so much myraman for all of those diagrams,now Im going out to try them out b4 week is out. The carb is standard has is motor only thing is dual flowmasters. I will check canister too you could be on to something there. I've never had a car with so many hoses.ill be checking everything now. It was purring b4 the fire so I'm sure I'll get it going right.goes to show you can't trust some mechanics.
Old Jan 16, 2014 | 06:59 PM
Deco Vegas's Avatar
Just come back from re routing the vacuum lines they were all over the place. It looks like a couple of things have been removed over time or blocked off.So I go to start it and guess what,a flat battery.back out there on weekend and try again. Thanks again for diagrams.
Old Jan 17, 2014 | 03:05 AM
Myraman's Avatar
I see Murphy showed up in your garage too. That would be Murphy of Murphy's law fame.. I'm surprised he made the trip to you, he's been in my garage for a long time!
Good luck
Old Jan 17, 2014 | 04:27 AM
bigblock's Avatar
Most of those hoses and wiring are not needed anyway. Just a few will get you back on the road.
Old Jan 17, 2014 | 05:21 PM
Deco Vegas's Avatar
Yeah Murphy has been here for awhile I had a 69 cougar with heaps of issues.Hopefully once charged all good.Im going to do more research and see what hoses need to be there, I shold have just put a Holley on it.
Old Jan 20, 2014 | 03:21 AM
Deco Vegas's Avatar
Went to start it but just wound over, so put some fuel down the carby kicked for a second.I think there might be vapour lock( it's extremely hot out here)Would a couple of the vacuum lines if not connected up right stop it from starting?Or maybe just fuel lock,how can I fix it?
xvodysseusvx
Jun 25, 2018 04:38 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
prive81
Aug 3, 2010 06:50 AM
James93726
Nov 11, 2007 10:48 AM
burnsy26
Oct 1, 2007 01:35 PM
