1999 Dodge Ram 1500 4x4
Old Jul 30, 2016 | 02:45 PM
Jimjimbo1942's Avatar
Check engine, brake, abs on dash. How many sensors and locations. What are steps to fix problem.Oh forgot speedometer works till I use brakes. Help !
Old Aug 1, 2016 | 06:14 PM
You need to put it on a scanner.. The speedo is controlled by a sensor on top of the rear diff. IT can also cause an ABS light
Old Aug 2, 2016 | 02:58 PM
Jim.... Check and make sure the fuses are good under the hood.... The ones in the black distribution box... Make sure the fuses under the Black clip and the Yellow or White are good.... Those are the main fuses, sounds to me like one of those blew out?
chuckorr
Feb 7, 2014 04:20 AM
checho
Oct 4, 2011 02:28 AM
Polishdog
Feb 1, 2010 01:04 AM
plymouthrr1985
May 25, 2009 05:22 PM
Ekimwood
Mar 15, 2009 04:40 AM
