Ticking
Old Jan 25, 2011 | 10:52 AM
M special's Avatar
Ticking
When i start my 03 300m special after it sits for awhile it sounds fine , then when i put it in gear there is a ticking sound that sounds like a lifter but it is more prominent when you listen down by the front wheel either side has anyone had this problem or does any one have any suggestions tranny fluid level is where it should be.
Old Jan 25, 2011 | 11:06 AM
Does the ticking happen when you are moving in gear or does it happen while you are sitting still in gear?
Old Jan 26, 2011 | 07:25 AM
M special's Avatar
Hey thanks for answering me back. I ticks while i'm driving it also speeds up with engine rpm
Old Jan 26, 2011 | 07:34 AM
when in neutral, there is no ticking, or it is just quieter?
Old Jan 26, 2011 | 08:53 AM
If it is only when you are moving, it could be a worn out CV shaft joint.
Old Jan 26, 2011 | 01:00 PM
I know I'm showing my age but what about a brake "tickler"?
Old Jan 26, 2011 | 06:38 PM
blue 68 gts's Avatar
Do you mean as if the pad is shifting because its missing a clip, or if its just squealing like a **** cause its so worn?
Old Jan 27, 2011 | 12:16 AM
M special's Avatar
hey thanks for your reply . In the morning or after it sits for a long time when i start it there is no ticking as soon as i put it in any gear the ticking starts its there when i'm driving if i put it in neutal while moving , while stopped in park , it ticks none stop the only time it isnt ticking is if it sits for long periods it can idle for half an hour after it sits and wont tick until its put in gear then it will tick all day long until it sits again
Old Jan 27, 2011 | 12:24 AM
M special's Avatar
it does it when the car is in park neutral drive, after i put it in gear after it sits it will tick all day all the time it never goes away until the car sits its none stop once it is put in gear . if i shut the car off and start it again after ive put it in gear that first time after it sat it will tick until it sit for a long time
Old Jan 29, 2011 | 08:47 PM
M special's Avatar
I dont know if you recieved my response to the question you asked me about my 03 300m special, ticking problem , i'm new to the forum and probably didnt answer you right , i answered you and a few others back and didnt hear back so i must of sent my response to you wrong , if you dont mind could you answer me back so i know if i'm answering you back right ,am i supposed to go to private message to respond to you,thanks
Old Jan 30, 2011 | 07:26 AM
you can just respond here on this thread
i like to use this quick reply box
it is on the bottom of the page
Old Jan 30, 2011 | 07:28 AM
Barfly's Avatar
Hey buddy , welcome to the forum.
You are doing things correctly, just keep posting here in this thread.
One thing you might consider though, is describing the circumstances of the problem in short sentences. For example:
I only hear the ticking when the car is warm.
The ticking starts as soon as I put it in gear.
The ticking continues even after I put the car in neutral.
When sentences all run together with a lack of punctuations like comma's, periods etc... it's difficult to understand.
A bunch of great guys willing to help around here, you are in the right place!
Joe.
Old Jan 30, 2011 | 06:04 PM
M special's Avatar
thanks for the input barfly and 67 GTX
profdel
Jun 13, 2012 10:34 AM
Arbiter343GS
Jun 7, 2012 01:33 PM
Jeftam
Jan 4, 2012 06:59 PM
SCRAPMAN1971
May 13, 2011 10:50 PM
DartSwinger
Aug 8, 2010 01:50 PM
