NHRA ORiley Nationals Charlotte
Old Sep 16, 2011 | 04:42 PM
Fri, 16 Sep 2011, 06:14 PM
Funny Car Qualifying Notes, Session #1
By Dave Rowe
CONCORD, N.C. - Notes from round 1 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Bob Gilbertson No Time, Now #1
5:36 p.m. Weather conditions: air temperature 63 degrees, relative humidity 49 percent, barometer 29.58 inches, adjusted altitude 1,139 feet, track temperature 79 degrees.
Gilbertson hits the throttle, gets about 100 feet out and backs off the throttle. Word from the track, the steering wheel came off in his hands.
Left Lane: John Smith Runs 4.208/289.94, Now #1
Right Lane: Melanie Troxel Runs 9.543/64.68, Now #2
Troxel has problems early in the run and clicks it off. Smith goes right down the groove and makes a decent pass.
Left Lane: Jim Head Runs 4.132/301.54, Now #2
Right Lane: Paul Lee Runs 4.118/309.49, Now #1
Lee keeps the candles lit all the way through the run and makes his quickest pass of the year to take the early pole. head makes a decent run and gets in the two spot for now.
Left Lane: Tony Pedregon Runs 4.167/294.11, Now #4
Right Lane: Johnny Gray Runs 4.087/312.78, Now #1
Two more clean, straight passes. Gray makes a decent pass, the fastest of his career, and he gets in the top spot for now.
Left Lane: Tim Wilkerson Runs 7.189/104.54, Now #7
Right Lane: Jeff Arend Runs 4.106/310.63, Now #2
Wilkerson has problems right off the line and the car noses over. Arend makes a clean pass and gets in the show in the second spot for now.
Left Lane: Bob Tasca III Runs 4.059/311.41, Now #1
Right Lane: John Force Runs 6.718/96.94, Now #8
Force rattles the tires off the line, pedals a couple of times, then gives up on the run. Tasca goes right down the groove and takes the pole for now.
Left Lane: Matt Hagan Runs 4.055/314.39, Now #1
Right Lane: Ron Capps Runs 7.057/84.93, Now #10
Capps hits the throttle, gets about 200 feet out and rattles the tires. Hagan goes right down the groove and moves into the top spot.
Left Lane: Cruz Pedregon Runs 4.538/185.92, Now #9
Right Lane: Robert Hight Runs 7.571/88.25, Now #13
Hight gets about 300 feet out and loses traction. Pedregon gets about 600 feet out, rattles the tires and has to click it off.
Left Lane: Jack Beckman Runs 5.642/122.82, Now #11
Right Lane: Mike Neff Runs 4.451/186.59, Now #9
Beckman gets about 400 feet out and has to back off the throttle. Neff made it a little further, loses traction and gives up on the run.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old Sep 17, 2011 | 05:15 PM
Round 2 Qualifying
Fri, 16 Sep 2011, 09:46 PM
Funny Car Qualifying Notes, Session #2
By Dave Rowe
CONCORD, N.C. - Notes from round 2 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Bob Gilbertson No Time, Now #17; No Prior Run
Gilbertson fired the engine, discovered a fuel leak and had to shut down.
Left Lane: Melanie Troxel Runs 4.049/308.85, Now #1; Best prior run: 9.543/64.68, Was #16
Right Lane: Tim Wilkerson Runs 4.108/305.84, Now #6; Best prior run: 7.189/104.54, Was #14
Troxel makes an impressive run, her quickest of the year, and she moves to the top of the order. Wilkerson goes right down the groove and gets in the top half of the field in the sixth spot.
Left Lane: Robert Hight Runs 4.060/314.90, Now #5; Best prior run: 7.571/88.25, Was #16
Right Lane: Jack Beckman Runs 4.044/318.92, Now #1; Best prior run: 5.642/122.82, Was #12
Beckman makes a great run here, right down the groove with his quickest pass of the year and the fastest Funny Car run ever to take the top spot. Hight goes right down the groove and moves all the way to the fifth spot.
Left Lane: Ron Capps Runs 7.923/75.68, Now #15; Best prior run: 7.057/84.93, Was #15
Right Lane: Cruz Pedregon Runs 8.204/84.77, Now #13; Best prior run: 4.538/185.92, Was #13
0-for-2 here, both drivers go up in smoke about 300 feet out and back off the throttle.
Left Lane: John Force Runs 11.429/50.43, Now #14; Best prior run: 6.718/96.94, Was #14
Right Lane: Tony Pedregon Runs 4.136/300.86, Now #10; Best prior run: 4.167/294.11, Was #10
Force goes up in smoke quickly and has to gie up on the run. Pedregon makes a clean run to improve but doesn't move up on the ladder.
Left Lane: Mike Neff Runs 4.038/314.17, Now #1; Best prior run: 4.451/186.59, Was #12
Right Lane: Jim Head Runs 8.141/80.48, Now #11; Best prior run: 4.132/301.54, Was #9
Head hits the throttle, gets about 60 feet out and goes up in smoke. No problems for Neff, right down the groove, header flames high and steady all the way through the run to take the top spot.
Left Lane: Jeff Arend Runs 4.048/313.44, Now #3; Best prior run: 4.106/310.63, Was #8
Right Lane: Bob Tasca III Runs 4.071/311.34, Now #6; Best prior run: 4.059/311.41, Was #5
Arend makes a great pass, the quickest and fastest of his career, and he moves into the third spot.
Left Lane: Johnny Gray Runs 5.037/150.97, Now #8; Best prior run: 4.087/312.78, Was #8
Right Lane: Matt Hagan Runs 3.995/316.23, Now #1; Best prior run: 4.055/314.39, Was #5
..and there it is, the first ever three second run in the Funny Car class. Hagan goes right down the groove and takes the top spot. He will have to run a 4.035 to back it up for a national record. Gray goes up in smoke quickly and has to back off the throttle.
Matt Hagan's incremental times: 60ft-0.886 sec., 330ft-2.281, 660ft-3.224/273.55 mph.
Old Sep 17, 2011 | 05:18 PM
Round 3 Qualifying
Sat, 17 Sep 2011, 01:34 PM
Funny Car Qualifying Notes, Session #3
By Dave Rowe
CONCORD, N.C. - Notes from round 3 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: Bob Gilbertson Runs 5.682/214.86, Now #13; No Prior Run
12:52 p.m. Weather conditions: air temperature 67 degrees, relative humidity 60 percent, barometer 29.62 inches, adjusted altitude 1,475 feet, track temperature 79 degrees.
Gilbertson has had his share of problems this weekend. The steering wheel came off in his hands on his first attempt, then he had to shut down before he could make a pass because of a fuel leak on his second attempt.
He gets down the track on this one but still had problems. The car makes a move to the left at the hit, then he strikes the tires about 300 feet out. He pedals, backs off the throttle, then gets back on it a little past half track.
Left Lane: John Smith Runs 4.193/299.73, Now #13; No Prior Run
Right Lane: Paul Lee Runs 5.361/137.08, Now #10; Best prior run: 4.118/309.49, Was #10
Smith made a decent pass yesterday, just not quick enough to get in the top twelve. Lee made his quickest pass of the year and is in the tenth spot right now.
Lee has problems about 300 feet out and has to abort the run. Smith goes right down the groove with his quickest pass of the weekend to get in the show in the 13th spot for now.
Left Lane: Cruz Pedregon Runs 5.186/141.77, Now #15; No Prior Run
Right Lane: John Force Runs 4.098/312.86, Now #9; No Prior Run
Both Force and Pedregon have had traction problems all weekend. Neither driver has made a full pass.
No problem for Force on this pass, right down the groove, candles lit all the way through the run. Pedregon hits the throttle, makes a little move to the right, then loses traction and backs off the throttle.
Left Lane: Jim Head Runs 11.345/55.80, Now #12; Best prior run: 4.132/301.54, Was #12
Right Lane: Ron Capps Runs 4.152/278.12, Now #14; No Prior Run
Capps keeps the slicks stuck for the first time this weekend and he gets in the show in the 14th spot for now. Head goes up in smoke quickly and has to give up on the run.
Left Lane: Tony Pedregon Runs 6.163/108.25, Now #13; Best prior run: 4.136/300.86, Was #13
Right Lane:
Pedregon has problems early in the run and has to click it off. Gray makes an impressive run and moves up a couple of spots to sixth.
Left Lane: Tim Wilkerson Runs 4.539/193.02, Now #10; Best prior run: 4.108/305.84, Was #10
Right Lane: Robert Hight Runs 5.286/140.63, Now #8; Best prior run: 4.060/314.90, Was #8
hight has traction problems about 300 feet out and has to click it off. Wilkerson was on a decent pass but had problems about 700 feet out and the car noses over.
Left Lane: Bob Tasca III Runs 5.228/142.00, Now #7; Best prior run: 4.059/311.41, Was #7
Right Lane: Melanie Troxel Runs 7.624/77.50, Now #5; Best prior run: 4.049/308.85, Was #5
0-for-2, Troxel strikes the tires about 200 feet out, Tasca loses traction about 300 feet out.
Left Lane: Jack Beckman Runs 5.947/112.96, Now #3; Best prior run: 4.044/318.92, Was #3
Right Lane: Jeff Arend Runs 8.229/77.01, Now #4; Best prior run: 4.048/313.44, Was #4
Traction problems again, both drivers up in smoke, Arend about 100 feet out, Beckman soon after.
Left Lane: Matt Hagan Runs 4.038/310.41, Now #1; Best prior run: 3.995/316.23, Was #1
Right Lane: Mike Neff Runs 5.673/122.47, Now #2; Best prior run: 4.038/314.17, Was #2
Hagan makes another great pass but not quite quick enough to back up his run yesterday for the record. He was on a really great run but green flames started coming from the headers about 700 feet out, then a fire developed underneath the car. The car is smoking pretty heavily just as he goes through the lights, then the Safety Safari has to roll to put out the flames.
Neff went up in smoke about 300 feet out.
Matt Hagan's incremental times: 60ft-0.888 sec., 330ft-2.300, 660ft-3.255/270.27 mph.
Old Sep 17, 2011 | 05:22 PM
Final Qualifying
Sat, 17 Sep 2011, 04:28 PM
Funny Car Qualifying Notes, Final Session
By Dave Rowe
CONCORD, N.C. - Notes from final, round 4 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Bob Gilbertson No Time, Now #17; Best prior run: 5.682/214.86, Was #17
Right Lane: Cruz Pedregon Runs 4.084/292.27, Now #9; Best prior run: 5.186/141.77, Was #16
3:38 p.m. Weather conditions: air temperature 69 degrees, relative humidity 59 percent, barometer 29.58 inches, adjusted altitude 1,665 feet, track temperature 78 degrees.
Gilbertson goes up in smoke at the hit and clicks it off. Pedregon goes right down the groove with his quickest pass of the weekend to get off the bump and into the ninth spot.
Left Lane: Ron Capps Runs 4.114/312.50, Now #12; Best prior run: 4.152/278.12, Was #15
Smith was scheduled to run with Capps but decided to skip this round.
Capps goes right down the groove with his quickest pass of the weekend and moves up a few spots to the 12th position.
Left Lane: John Force Runs 4.100/312.28, Now #10; Best prior run: 4.098/312.86, Was #10
Right Lane: Tony Pedregon Runs 4.168/293.66, Now #15; Best prior run: 4.136/300.86, Was #15
A good side-by-side, both right down the middle of the track. Force doesn't improve but makes a good run just a little off his qualifying pace. Pedregon makes his third decent pass of the weekend.
Left Lane: Robert Hight Runs 4.544/190.19, Now #8; Best prior run: 4.060/314.90, Was #8
Right Lane: Jim Head Runs 10.314/65.68, Now #14; Best prior run: 4.132/301.54, Was #14
Head goes up in smoke right about 60 feet out and clicks it off. Hight was on a decent pass, then the engine went silent about 800 feet out, not sure why.
Left Lane: Johnny Gray Runs 4.054/314.68, Now #6; Best prior run: 4.058/313.58, Was #6
Right Lane: Tim Wilkerson Runs 4.096/309.63, Now #10; Best prior run: 4.108/305.84, Was #11
Wilkerson goes right down the groove with his quickest pass of the weekend and moves up a spot to tenth. Gray improves a little and stays in the sixth spot.
Left Lane: Melanie Troxel Runs 4.042/291.76, Now #3; Best prior run: 4.049/308.85, Was #5
Right Lane: Bob Tasca III Runs 4.655/180.21, Now #7; Best prior run: 4.059/311.41, Was #7
Tasca started mixing up cylinders early and backed off the throttle about 800 feet out. Troxel made her quickest pass of the year and moved up a couple of spots to third.
Left Lane: Jeff Arend Runs 6.075/109.74, Now #5; Best prior run: 4.048/313.44, Was #5
Right Lane: Jack Beckman Runs 5.075/151.99, Now #4; Best prior run: 4.044/318.92, Was #4
Arend gets about 400 feet out, starts moving around and clicks it off. Beckman had traction problems about 600 feet out and backed off the throttle.
Left Lane: Mike Neff Runs 5.529/127.17, Now #2; Best prior run: 4.038/314.17, Was #2
Right Lane: Matt Hagan Runs 7.250/88.96, Now #1; Best prior run: 3.995/316.23, Was #1
Hagan gets about 300 feet out and goes up in smoke. Neff gets a little further and loses traction.
Old Sep 19, 2011 | 08:47 AM
Summary of Eliminations
Sun, 18 Sep 2011, 08:06 PM
Summary of Eliminations in Funny Car
CONCORD, N.C. - Summary of eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, Fourth annual O'Reilly Auto Parts NHRA Nationals:
Round 1:
Jack Beckman, Norco CA, '10 Charger, Right lane, (0.082) 4.092 316.01 def. Paul Lee, Anaheim CA,'10 Impala SS, (0.092) 8.312 79.30
Jim Head, Columbus OH, '10 Solara, Left lane, (0.082) 4.154 295.46 def. Melanie Troxel, Duluth GA,'10 Solara, (0.099) 5.877 124.68
Matt Hagan, Brownsburg IN, '10 Charger, Right lane, (0.083) 4.018 322.27 def. John Smith, AndersonSC, '06 Monte Carlo, (0.080) 6.564 103.85
Mike Neff, Yorba Linda CA, '11 Mustang, Right lane, (0.086) 4.490 255.92 def. Tony Pedregon,Brownsburg IN, '10 Impala SS, (0.077) 4.973 224.58
Jeff Arend, San Dimas CA, '10 Solara, Right lane, (0.102) 4.103 311.77 def. Ron Capps, Carlsbad CA,'10 Charger, (0.065) 4.999 179.85
Johnny Gray, Artesia NM, '10 Charger, Right lane, (0.098) 4.354 238.43 def. John Force, Yorba LindaCA, '11 Mustang, (0.069) 5.751 122.49
Tim Wilkerson, Springfield IL, '11 Mustang, Left lane, (0.081) 4.121 306.88 def. Bob Tasca III,Cranston RI, '11 Mustang, (0.065) 5.171 152.42
Cruz Pedregon, Brownsburg IN, '10 Solara, Left lane, (0.093) 4.329 265.69 def. Robert Hight, YorbaLinda CA, '11 Mustang, (0.065) 6.431 104.66
Round 2:
J Gray, Left lane, (0.090) 5.055 255.82 def. J Head, (0.099) 5.238 272.83
M Hagan, Right lane, (0.106) 4.054 316.38 def. C Pedregon, (0.076) 4.108 305.98
M Neff, Left lane, (0.100) 4.076 312.35 def. T Wilkerson, (0.070) 4.133 306.95
J Beckman, Right lane, (0.067) 4.083 318.99 def. J Arend, (0.079) 5.223 146.54
Round 3:
M Neff, Right lane, (0.081) 4.080 309.91 def. J Gray, (0.072) 4.118 311.20
M Hagan, Right lane, (0.057) 4.032 318.69 def. J Beckman, (0.043) 4.090 317.79
Round 4:
M Hagan, Right lane, (0.090) 4.130 301.07 def. M Neff, (0.077) 4.431 202.79
Low ET: Matt Hagan 3.995 seconds
Top Speed: Matt Hagan 322.27 MPH
MReeves
Super Gas
Apr 14, 2012 09:11 AM
MReeves
Pro-Stock
Sep 19, 2011 08:39 AM
MReeves
Stock Eliminator
Sep 17, 2011 05:32 PM
MReeves
Super Stock
Sep 17, 2011 05:27 PM
MReeves
Super Gas
Sep 16, 2011 04:33 PM
