NHRA Route 66 Nationals Joliet
Old Jul 8, 2011 | 05:28 PM
Fri, 8 Jul 2011, 06:32 PM
Funny Car Qualifying Notes, Session #1
By Dave Rowe
JOLIET, Ill. - Notes from round 1 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Terry Haddock Runs 4.566/266.16, Now #1
4:54 p.m. Weather conditions: air temperature 92 degrees, relative humidity 30 percent, barometer 29.18 inches, adjusted altitude 3,566 feet, track temperature 128 degrees.
Haddock loses a cylinder early but stays on the throttle all the way through the lights.
Left Lane: Dale Creasy Jr. Runs 6.542/104.15, Now #3
Right Lane: Bob Bode Runs 5.195/147.89, Now #2
Creasy gets about 300 feet out and strikes the tires. Bode gets a little further, loses traction and backs off the throttle.
Left Lane: Melanie Troxel Runs 5.840/139.07, Now #3
Right Lane: Paul Lee Runs 6.827/95.98, Now #5
Lee gets about 200 feet out and goes up in smoke. Troxel smokes the tires at the same time, pedals once, then gives up on the run.
Left Lane: Tony Pedregon Runs 4.373/222.88, Now #1
Right Lane: Tim Wilkerson Runs 5.121/156.37, Now #3
Wilkerson gets about 400 feet out and goes up in smoke. Pedregon gets out of the groove about 800 feet out, makes a move toward the center line and has to back off the throttle.
Left Lane: Johnny Gray Runs 4.394/230.13, Now #2
Right Lane: Bob Tasca III Runs 4.976/159.59, Now #4
Tasca makes it about 500 feet and goes up in smoke. Gray made it about 700 feet and lost traction.
Left Lane: Jeff Arend Runs 4.335/278.06, Now #1
Right Lane: John Force No Time, Now #11
Force hits the throttle, moves about two feet and stops. He sits there for a second, the chutes pop out and he idles over to the wall. Word from the track is the throttle cable broke. Arend is able to keep the slicks stuck and takes the top spot for now.
Left Lane: Ron Capps Runs 4.218/291.32, Now #1
Right Lane: Matt Hagan Runs 4.320/243.19, Now #2
Capps makes a good run for the conditions and takes the pole for now. Hagan's car loses power early but he still makes it all the way to the second spot.
Left Lane: Cruz Pedregon Runs 5.039/216.24, Now #8
Right Lane: Robert Hight Runs 5.106/235.89, Now #9
Hight and Pedregon both strike the tires early, both get on and off the throttle several times just trying to get in the field.
Left Lane: Jack Beckman Runs 6.976/89.54, Now #16
Right Lane: Mike Neff Runs 4.778/178.80, Now #7
Neff gets about 400 feet out, strikes the tires, pedals once and heads for the center line. Beckman loses traction early and gives up on the run quickly.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old Jul 9, 2011 | 03:55 AM
Round 2 Qualifying
Fri, 8 Jul 2011, 09:32 PM
Funny Car Qualifying Notes, Session #2
By Dave Rowe
JOLIET, Ill. - Notes from round 2 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: John Force Runs 6.129/110.04, Now #15; No Prior Run
Right Lane: Justin Schriefer Runs 4.532/228.46, Now #6; No Prior Run
7:57 p.m. Weather conditions: air temperature 86 degrees, relative humidity 41 percent, barometer 29.19 inches, adjusted altitude 3,295 feet, track temperature 103 degrees.
Force gets about 300 feet out and goes up in smoke. He pedals once then gives up on the run. Schriefer gets about 600 feet out, strikes the tires, pedals once and gives up on the run.
Left Lane: Paul Lee Runs 6.938/94.77, Now #18; Best prior run: 6.827/95.98, Was #17
Right Lane: Jack Beckman Runs 4.139/291.51, Now #1; Best prior run: 6.976/89.54, Was #18
Lee gets about 200 feet out, strikes the tires and backs off the throttle. Beckman makes a good run and moves all the way to the top of the pack.
Left Lane: Bob Bode Runs 4.246/289.20, Now #3; Best prior run: 5.195/147.89, Was #14
Right Lane: Dale Creasy Jr. Runs 6.888/102.10, Now #17; Best prior run: 6.542/104.15, Was #17
Creasy goes up in smoke and has to give up on the run. Bode makes a good run and moves up to the third spot.
Left Lane: Tim Wilkerson Runs 4.182/296.83, Now #3; Best prior run: 5.121/156.37, Was #14
Right Lane: Melanie Troxel Runs 4.155/285.29, Now #2; Best prior run: 5.840/139.07, Was #15
Troxel started moving around late in the run but hung on to move into the second spot. Wilkerson went right down the groove and moves up to the third spot.
Left Lane: Robert Hight Runs 5.440/139.56, Now #15; Best prior run: 5.106/235.89, Was #15
Right Lane: Cruz Pedregon Runs 4.165/295.08, Now #3; Best prior run: 5.039/216.24, Was #14
Pedregon is running with Wounded Warrior Project livery this weekend in honor of wounded veterans of the Afghanistan and Iraq wars. Over fifty wounded warriors will be the guests of Snap-On and Pedregon here this weekend.
Hight gets about 300 feet out and strikes the tires. he pedals in an attempt to save the run but finally gives up about 600 feet out. Pedregon goes right down the groove and moves all the way to the third spot.
Left Lane: Bob Tasca III Runs 4.180/298.54, Now #4; Best prior run: 4.976/159.59, Was #14
Right Lane: Johnny Gray Runs 5.110/147.94, Now #11; Best prior run: 4.394/230.13, Was #10
Tasca goes right down the groove and moves up to the fourth spot. Gray was on a decent pass but had traction problems near the end of the run.
Left Lane: Mike Neff Runs 4.110/298.01, Now #1; Best prior run: 4.778/178.80, Was #14
Right Lane: Tony Pedregon Runs 4.245/271.41, Now #8; Best prior run: 4.373/222.88, Was #10
Neff goes right down the groove, candles lit all the way through the run, and he takes the pole for now. Pedregon makes a solid run and moves up a couple of spots.
Left Lane: Terry Haddock Runs 4.393/277.43, Now #12; Best prior run: 4.566/266.16, Was #14
Right Lane: Jeff Arend Runs 4.199/294.31, Now #7; Best prior run: 4.335/278.06, Was #11
A good side-by-side, both down the groove to get in the field. Haddock gets in on the bump, Arend moves to the seventh spot.
Left Lane: Matt Hagan Runs 4.114/296.18, Now #2; Best prior run: 4.320/243.19, Was #11
Right Lane: Ron Capps Runs 4.135/301.94, Now #3; Best prior run: 4.218/291.32, Was #8
A couple of good, solid runs to end the session, Hagan moves into the second spot, Capps right behind in the third spot.
Old Jul 10, 2011 | 04:57 AM
Round 3 Qualifying
Sat, 9 Jul 2011, 07:24 PM
Funny Car Qualifying Notes, Session #3
By Dave Rowe
JOLIET, Ill. - Notes from round 3 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Paul Lee Runs 4.582/198.23, Now #14; No Prior Run
Right Lane: Dale Creasy Jr. Runs 4.411/279.27, Now #13; No Prior Run
5:52 p.m. Weather conditions: air temperature 93 degrees, relative humidity 41 percent, barometer 29.21 inches, adjusted altitude 3,873 feet, track temperature 137 degrees.
Lee was on a decent pass but started hazing the tires about 700 feet out. Creasy makes a clean pass and gets in the show for now.
Left Lane: John Force Runs 4.301/276.24, Now #12; No Prior Run
Right Lane: Johnny Gray Runs 5.037/201.61, Now #16; No Prior Run
force finally gets all the way down the track under power and he gets in the show in the 12th spot. Gray gets about 600 feet out and hazes the tires.
Left Lane: Robert Hight Runs 4.287/289.94, Now #12; No Prior Run
Hight goes right down the groove with his quickest pass of the weekend and gets in the field in the 12th spot for now.
Left Lane: Terry Haddock Runs 5.396/138.36, Now #14; Best prior run: 4.393/277.43, Was #14
Right Lane: Tony Pedregon Runs 4.898/165.70, Now #10; Best prior run: 4.245/271.41, Was #10
haddock gets about 400 feet out, the car gets loose and he has to back off the throttle. Pedregon gets a little further, loses traction and gives up the run.
Left Lane: Bob Bode Runs 5.619/144.47, Now #11; Best prior run: 4.246/289.20, Was #11
Right Lane: Jeff Arend Runs 7.252/91.01, Now #9; Best prior run: 4.199/294.31, Was #9
Arend gets about 200 feet out and goes up in smoke, Bode follows suit just a little further down track.
Left Lane: Tim Wilkerson Runs 4.202/297.16, Now #8; Best prior run: 4.182/296.83, Was #8
Right Lane: Cruz Pedregon Runs 5.161/144.30, Now #6; Best prior run: 4.165/295.08, Was #6
Pedregon gets about 400 feet out and strikes the tires. Wilkerson goes right down the groove with the quickest pass of the round so far.
Left Lane: Bob Tasca III Runs 4.261/293.22, Now #7; Best prior run: 4.180/298.54, Was #7
Right Lane: Melanie Troxel Runs 4.341/251.11, Now #5; Best prior run: 4.155/285.29, Was #5
This was a good side-by-side until they get about 800 feet out. Troxel starts hazing the tires at that point and then the blower belt comes apart.
Left Lane: Matt Hagan Runs 4.225/284.03, Now #2; Best prior run: 4.114/296.18, Was #2
Right Lane: Jack Beckman Runs 4.239/289.07, Now #4; Best prior run: 4.139/291.51, Was #4
These two were glued together all the way through the run. Neither driver improves but make decent runs for the conditions.
Left Lane: Mike Neff Runs 4.280/252.28, Now #1; Best prior run: 4.110/298.01, Was #1
Right Lane: Ron Capps Runs 6.360/101.07, Now #3; Best prior run: 4.135/301.94, Was #3
Capps gets about 300 feet out and strikes the tires. Neff makes a solid pass but doesn't improve.
Old Jul 10, 2011 | 05:00 AM
Final Qualifying
Sat, 9 Jul 2011, 10:06 PM
Funny Car Qualifying Notes, Final Session
By Dave Rowe
JOLIET, Ill. - Notes from final, round 4 qualifying in Funny Car at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Justin Schriefer Runs 4.429/272.78, Now #16; No Prior Run
Right Lane: Paul Lee No Time, Now #17; Best prior run: 4.582/198.23, Was #16
8:34 p.m. Weather conditions: air temperature 85 degrees, relative humidity 55 percent, barometer 29.21 inches, adjusted altitude 3,387 feet, track temperature 104 degrees.
Lee did his burnout but was unable to back up. He gets out of the car to allow Schriefer to make his run. Schriefer goes right down the groove with his quickest pass of the weekend to get in on the bump.
Left Lane: Johnny Gray Runs 6.391/103.36, Now #18; Best prior run: 5.037/201.61, Was #18
Right Lane: Terry Haddock Runs 9.479/101.20, Now #14; Best prior run: 4.393/277.43, Was #14
Haddock hits the throttle and goes up in smoke. Gray gets about 300 feet out, strikes the tires, then has to give up on the run.
Right Lane: John Force Runs 4.158/295.14, Now #6; Best prior run: 4.301/276.24, Was #13
Force goes right down the groove with his quickest pass of the weekend and moves up to the sixth spot.
Left Lane: Tony Pedregon Runs 4.194/297.61, Now #10; Best prior run: 4.245/271.41, Was #11
Right Lane: Robert Hight Runs 4.386/216.17, Now #13; Best prior run: 4.287/289.94, Was #13
Hight was on a decent run but the candles go out about 800 feet out. Pedregon makes his quickest pass of the weekend and moves up a spot on the ladder.
Left Lane: Jeff Arend Runs 7.577/78.56, Now #11; Best prior run: 4.199/294.31, Was #11
Right Lane: Bob Bode Runs 4.273/283.19, Now #12; Best prior run: 4.246/289.20, Was #12
Arend, still having traction problems, gets about 300 feet out and goes up in smoke. Bode makes a clean pass but doesn't improve.
Left Lane: Cruz Pedregon Runs 4.159/298.34, Now #7; Best prior run: 4.165/295.08, Was #7
Right Lane: Tim Wilkerson Runs 5.678/123.09, Now #9; Best prior run: 4.182/296.83, Was #9
Wilkerson gets about 400 feet out and goes up in smoke. Pedregon makes a solid pass but doesn't improve.
Left Lane: Melanie Troxel Runs 7.394/88.98, Now #5; Best prior run: 4.155/285.29, Was #5
Right Lane: Bob Tasca III Runs 5.578/125.31, Now #8; Best prior run: 4.180/298.54, Was #8
Troxel gets about 300 feet out, strikes the tires and backs off the throttle. Tasca gets a little further and goes up in smoke.
Left Lane: Jack Beckman Runs 5.290/137.16, Now #4; Best prior run: 4.139/291.51, Was #4
Right Lane: Matt Hagan Runs 4.637/181.79, Now #2; Best prior run: 4.114/296.18, Was #2
Beckman gets out of shape about 300 feet out and backs off the throttle. Hagan gets out of the groove, makes a hard move toward the centerline a little past half track, and has to back off the throttle to save the run.
Left Lane: Ron Capps Runs 4.480/198.50, Now #3; Best prior run: 4.135/301.94, Was #3
Right Lane: Mike Neff Runs 4.135/304.19, Now #1; Best prior run: 4.110/298.01, Was #1
Capps was on a pretty good run until just past the 600 foot mark, then he strikes the tires and has to give up on the run. Neff makes an impressive run, the quickest of the round, and picks up the three bonus points.
That does it for the night. We'll be back at 8:00 with Sportsman eliminations.
Old Jul 11, 2011 | 05:25 AM
Summary of Eliminations
Sun, 10 Jul 2011, 06:38 PM
Summary of Eliminations in Funny Car
JOLIET, Ill. - Summary of eliminations in Funny Car at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals:
Round 1:
Melanie Troxel, Duluth GA, '10 Solara, Left lane, (0.109) 5.732 174.08 def. Bob Bode, BarringtonIL, '10 Solara, (0.113) 16.680 30.89
Ron Capps, Carlsbad CA, '10 Charger, Left lane, (0.103) 4.476 243.24 def. Terry Haddock, Temple TX,'10 Solara, (0.138) 7.431 94.51
Dale Creasy Jr., Beecher IL, '10 Impala SS, Right lane, (0.127) 4.396 268.06 def. Matt Hagan,Brownsburg IN, '10 Charger, (0.096) 4.620 259.91
Mike Neff, Yorba Linda CA, '11 Mustang, Right lane, (0.318) 4.257 289.32 def. Justin Schriefer,Grant Park IL, '04 Camaro, (-0.275 foul) 11.266 77.81
Jack Beckman, Norco CA, '10 Charger, Right lane, (0.065) 4.300 282.48 def. Robert Hight, YorbaLinda CA, '11 Mustang, (0.047) 4.448 279.90
Jeff Arend, San Dimas CA, '10 Solara, Right lane, (0.107) 4.331 280.02 def. John Force, Yorba LindaCA, '11 Mustang, (0.088) 4.362 283.07
Tony Pedregon, Brownsburg IN, '10 Impala SS, Left lane, (0.097) 4.353 279.09 def. Cruz Pedregon,Brownsburg IN, '10 Solara, (0.065) 4.603 278.00
Bob Tasca III, Cranston RI, '11 Mustang, Right lane, (0.074) 4.277 292.96 def. Tim Wilkerson,Springfield IL, '11 Mustang, (0.098) 4.270 286.13
Round 2:
T Pedregon, Left lane, (0.097) 4.318 288.33 def. D Creasy Jr., (0.156) 10.366 81.42
J Arend, Right lane, (0.088) 4.361 281.42 def. R Capps, (0.096) 4.598 266.16
M Neff, Right lane, (0.086) 4.223 295.08 def. B Tasca III, (0.083) 4.234 294.11
J Beckman, Right lane, (0.114) 4.278 287.53 def. M Troxel, (0.114) 4.340 248.93
Round 3:
J Arend, Right lane, (0.071) 4.671 228.34 def. T Pedregon, (0.071) 8.259 95.84
M Neff, Right lane, (0.089) 4.252 296.05 def. J Beckman, (0.073) 4.314 285.53
Round 4:
M Neff, Right lane, (0.088) 4.246 293.22 def. J Arend, (0.094) 5.168 186.54
Low ET: Mike Neff 4.110 seconds
Top Speed: Mike Neff 304.19 MPH
MReeves
Pro-Stock
Jun 29, 2014 02:28 PM
MReeves
Pro-Stock
Jul 11, 2011 05:14 AM
MReeves
Stock Eliminator
Jul 10, 2011 12:46 PM
MReeves
Super Stock
Jul 10, 2011 08:39 AM
MReeves
Super Gas
Jul 8, 2011 09:13 AM
