1993 Carbureted Magnum, with 1974 Dodge dart stock tranny
Old Dec 2, 2012 | 12:03 AM
Canyon's Avatar
Ok, so first off I'm unaware of what type of transmission is. But I have a 1993 5.9L 360 Magnum that is carbureted my only question is if it would bolt up to my tranny.
All help is appreciated, thanks.
Old Dec 2, 2012 | 05:30 AM
Gorts 5th's Avatar
Smile
what motor did that dart have?
the 318 most likely, it had a 904 trany the converter needs to be changed i don't think you can get one for it
you need a 727, hec the power will eat up the poor 904
- or with modification a 500 or a 518.
Old Dec 2, 2012 | 06:31 AM
Chryco Psycho's Avatar
yes it will bolt up , the 5.9 Magnum & LA 360 are balanced differently so you will need a different converter or flex plate for that
Old Dec 2, 2012 | 01:26 PM
Canyon's Avatar
Alright, how much do you think a manual 727 would run me?
Old Dec 2, 2012 | 02:27 PM
Archer's Avatar
Canyon -
TCI has MVB tranny's in the $1500 range.
Add the new converter, etc and possible drive shaft mods and you're looking the $2000 range. Used may be an option, but with trannys that can be risky, unless you're up for a rebuild.
Old Dec 2, 2012 | 04:23 PM
Gorts 5th's Avatar
Smile
theygot nice stuff
http://www.transmissioncenter.net/
Old Dec 2, 2012 | 07:23 PM
Canyon's Avatar
Ok, this link is from my local craigslist type website, I was wondering if this 727 would work and bolt up to a 1974 dodge dart swinger.
http://www.ksl.com/index.php?nid=218...20transmission
Old Dec 2, 2012 | 11:38 PM
Your current 904/999/ trans can be made to work. But you would be better off with a 727. That trans in the add is a small block 727 and will work. Will bolt in without problems. You will need to have your drive shaft shortened & change the trans yoke. Personally I would have a complete new drive shaft made...
The later Magnum has it's balance weights on the flex plate, early one's may have weights on the torque converter so you need to check !!!
Old Dec 3, 2012 | 12:01 AM
Canyon's Avatar
Ok, how much do you think it would run me for all of that. Also how do you check for the weights (sorry not much experience with trannys).
Old Dec 3, 2012 | 05:15 AM
in the link you posted you can see the weight welded to the front face of the converter Cost - I would rebuild the trans & that converter will be wrong for a Magnum engine so it could run $1000 for a new converter + rebuilding the trnas + manual valve body conversion after you buy that trans
Old Dec 3, 2012 | 02:05 PM
Canyon's Avatar
^ Is this true i've had some people tell me it will bolt right up to the magnum and now some people tell me it won't.
Old Oct 1, 2014 | 06:49 AM
DodgeAddict's Avatar
The 904 will of course bolt to the 360 Magnum but will require a Flexplate to fit the 904 converter
Feb 3, 2015 08:59 AM
MReeves
Stock Eliminator
Dec 12, 2011 10:26 AM
rickyr
Feb 3, 2011 07:31 AM
Austin The Rat-Rod Kid
Sep 13, 2010 08:49 AM
Sep 10, 2010 06:30 PM
