318 in my 66
Old 07-10-2009 | 02:51 PM
fury_19's Avatar
Question 318 in my 66
my 66 is runnin like crap... stalls out alot wen i come to a stop... has new plugs, wires, points, and re built the original carb... my buddy is sayin needs new heads or a valve job and possble a diff carb (stromburg is wats in it) any suggestions on wat i should get or if i should try somethin else?
Old 07-11-2009 | 01:24 AM
deadkelly's Avatar
dose it pop fart & carry on when your driving ? whats your fuel filter like or fuel pump . have you ran your tank low . ?
Old 07-11-2009 | 01:30 PM
dingo's Avatar
Junior Member
sound like its in the fuel filter or carb
Old 07-11-2009 | 04:01 PM
theomahamoparguy's Avatar
thoe needle and seats in those carbs have a tendency to stick. Might try a newer carb like a Carter.
Old 12-14-2009 | 01:43 PM
Frank the Tank's Avatar
Check the idle speed while in gear. I had the same problem. You will be suprised what a 50-100 rpm differance can do.
waham87
02-22-2013 06:46 PM
hcharles
02-05-2011 03:52 PM
TallChris
12-01-2010 03:29 PM
LittleSpark
01-15-2009 09:06 PM
ProEmaster
06-06-2007 11:31 AM
Quick Reply: 318 in my 66
