318 Poly missing Valve Lash Adjusters HELP!
Old Oct 15, 2016 | 09:21 PM
Olie24's Avatar
Hi there, i recently swapped a 318 poly into my 67 dodge d200 that had a slant six and I just got it runni g good enough to drive.
Anyways, i went to adjust the valves on it, and after pulling the valve covers, there was no studs or anything for adjusting the valve clearances.
I was stumped and now I am wondering how i am supposed to adjust them? Or if i even can and why it was no studs or screws? Ill post a pic below so you all know what im getting at here.
Any help is appreciated. Thanks!
Attached Thumbnails 318 Poly missing Valve Lash Adjusters HELP!-20161014_222532.jpg   318 Poly missing Valve Lash Adjusters HELP!-20161014_222528.jpg
Old Oct 17, 2016 | 10:29 PM
My guess would be that you have hydrolic lifters no adjustment needed.. Check clearance when the valve is closed
Old Oct 18, 2016 | 07:29 PM
I dont remember how the poly's got adjusted.... If memorie serves me rite? I thought they used valve stem caps to take up clearance on them old dogs?
I think some guys went to adjustable push rods or rocker arms from a later poly motor... Sorry.
Old Feb 6, 2017 | 04:27 PM
t65fury3's Avatar
did you find out to adjust i have a 65 poly
tcgrump
Feb 4, 2016 01:20 PM
Mrpyro187
Nov 16, 2012 09:09 AM
Mr. Belvedere II
Jun 21, 2012 09:52 AM
smackhonda
May 14, 2010 05:30 AM
DUST360
Oct 11, 2009 09:54 AM
