318 question
Mike -
Well, maybe...
Will it make any real difference, maybe a little, and if you don't have a lead foot, you'll get better mileage, assuming you pick the right size carb, of course.
The real reason to do that,would be because bucks are tight, and you can start with the carb and get the manifold a little later, but again, lets be real, 318 manifolds aren't that expensive, especially if you look at the used market.
Unfortunately, the carb/manifold swap is only the first step, then headers, cam, etc.
Well, maybe...
carb mfg. mite have a conversation kit check with them. Because I have no idea what carb you have at this time.
