318 question
Old Apr 23, 2019 | 12:01 PM
Mike68's Avatar
318 question
I have a 1981 Dodge W150. It has a 2 barrel intake, if I get a 4 barrel adapter and 4 barrel carburetor would it make a difference?
Old Apr 23, 2019 | 01:36 PM
Save your money......
Old Apr 23, 2019 | 02:05 PM
Better to get the rite manifold and the correct linkage..... I agree... Save your money.
Old Apr 24, 2019 | 06:11 AM
Archer's Avatar
Mike -
Well, maybe...
Will it make any real difference, maybe a little, and if you don't have a lead foot, you'll get better mileage, assuming you pick the right size carb, of course.
The real reason to do that,would be because bucks are tight, and you can start with the carb and get the manifold a little later, but again, lets be real, 318 manifolds aren't that expensive, especially if you look at the used market.
Unfortunately, the carb/manifold swap is only the first step, then headers, cam, etc.
Old Apr 24, 2019 | 08:03 AM
Save your money
Old Apr 28, 2019 | 03:11 PM
Sammyes1998's Avatar
Since yall are talking about carbs. My brother in law has an 83 318 with electric choke but the electric part doesnt work, is there a way to rig it to make it manual?
Old Apr 28, 2019 | 05:20 PM
carb mfg. mite have a conversation kit check with them. Because I have no idea what carb you have at this time.
Old Apr 28, 2019 | 06:20 PM
Sorry, its a 2 barrel
Old Apr 29, 2019 | 05:48 AM
Check the power to the choke thermostat. If it's not getting voltage, then the resister may be bad and need replacing.
Old Apr 29, 2019 | 05:51 AM
Getting 0 voltage. Ill go ahead and see if an autoparts store has one when i get off work later
Old Apr 29, 2019 | 06:03 AM
Before you buy one... Make sure you have voltage/power to the timer first. Might not be hooked up for some reason? Or maybe the feed/power wire is broken?
wayne57
Dec 27, 2016 02:52 PM
dougfunnie
21
Apr 10, 2014 12:47 AM
tracktor312
Dec 5, 2010 06:23 PM
slacker200
Nov 10, 2009 03:34 AM
skymynx
Nov 12, 2008 09:55 AM
