360 swapp
Old Oct 6, 2008 | 06:21 PM
ef8340's Avatar
Senior Member
goodluck with it 72 ive never done it before but if you find the info you need on here im up in athens ga and could possibly give you a hand have you tried north georgia mopar club they have alot of members and might aswell be able to help you
Old Oct 7, 2008 | 12:48 AM
you will have to cut and splice in new wiring into the truck harness to lengthen some spots, you will need to convert the tranny from 4wd to 2wd (if everything is out of a 4wd truck), you'll need to have a fuel pump for the EFI, you'll have to modify the dash to accept the cluster, you might/probably will have to modify the cross member for the tranny, and there is a lot of other things that I am probably missing as well.
I've never done something like this before either, but I bet it will be sick once you get it done.
Old Oct 7, 2008 | 10:42 AM
Commando's Avatar
Why modify it from 4wd, I think it would be really cool to have a 4wd Sebring, if you can get it all to fit.
Old Oct 8, 2008 | 12:58 AM
that would be sick if it was 4wd or AWD
Old Oct 16, 2008 | 08:28 PM
challenger's Avatar
72 from my understanding you will need all the wiring out of the 02 to make your engine and trans work as everything is mostly computerized , it is a computerized world after around 94 or so but im sure with everything from the donor truck you should have everything you need
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
jej
Nov 17, 2014 07:59 AM
keith811
Jan 13, 2011 10:43 AM
choelzer
Feb 29, 2008 03:00 AM
