Chasing oil leaks on my 225
Old Apr 17, 2022 | 04:51 PM
Tug guy's Avatar
Lightbulb Chasing oil leaks on my 225
got this here Mopar Delux and I'm trying to keep all the oil I put in it. just trying to gauge where I should start and so I ask the Mopar community. what are the most common oil leaks on a 1972 225? and which ones are the cheapest to do first?
Old Apr 17, 2022 | 05:36 PM
If you have a rear mail leaking you might as well pull the motor and fix them all. Just be positive about the sorce of the leaks first…
Old Apr 17, 2022 | 05:37 PM
I would say, If it has a lot of leaks, Just buy a gasket overhaul kit, Pull the engine out, Put it on an engine stand and go threw it and clean all the surfaces and install new gaskets and seals all the way around.
Check the engine compression before hand, just to make sure it is in good shape. And also check it for crankcase pressure, to make sure it is not excessive.
Old Apr 17, 2022 | 05:38 PM
lol... You beat me too it Tom... Cheers
Old Apr 17, 2022 | 07:44 PM
Before crawling under that make sure you have both an extra HD jack and stands or RR ties.
Old Apr 18, 2022 | 11:21 AM
the usual suspects are oil pan and valve cover gaskets. i'd start there if it's marking its territory too often!
Old Apr 19, 2022 | 06:04 AM
Tug guy's Avatar
Talking
It definitely loves marking its territory, maybe ill start there. as much as I'd love to pull the motor on this thing, I currently don't have the time for that. I gotta keep it up and running too, she a workin girl.
Old Apr 19, 2022 | 07:39 AM
Last Tug I worked on was for the LAX here in So-Cal.... But it had a Detroit 8V92 in it.... Talk about a pain in the Azz to work on....
Old Apr 19, 2022 | 12:32 PM
There’s really no quick fix for oil leaks.
Old Apr 22, 2022 | 07:42 AM
True
Rsrfoto
Nov 21, 2018 07:03 AM
rexus31
Feb 5, 2014 12:46 AM
scrapmetal
Sep 12, 2011 02:32 AM
06_SRT8
Feb 18, 2010 11:26 AM
Aug 4, 2009 03:51 PM
