Good set up?
Old Jul 15, 2009 | 09:55 AM
I'm not one for Weiand intakes. I had one kind of on a 78 318, it actually wouldn't bolt up or sit down all the way. You might want to keep an eye on that. FYI
Old Jul 15, 2009 | 06:07 PM
Tim, were you heads ever milled on that 78?
Maybe thats why the intake didn't fit right
Old Jul 15, 2009 | 06:08 PM
lifters need pushrods
get an adjustable pushrod first, then measure the exact size push rods you need
Old Jul 15, 2009 | 10:44 PM
chlngr1970's Avatar
Originally Posted by zane kiser
And i can not find the lifters for the valves..because all mopar offers is hydrolic lifters....will those even work on a pushrod engine?
All OHV engines have lifters that rest on the cam. That is the small cylinder between the cam and the push rod. They usually come in a kit with the cam.
j
Old Jul 15, 2009 | 11:04 PM
theomahamoparguy's Avatar
Im not sure of the pushrods. Make sure that they are compatible with the "LA" type of cylinder heads. Call comp cams and tell them what you are going to be using on the engine. Everything else it seems should work. Like an eldebrock intake better.
Old Aug 1, 2009 | 02:43 PM
67Polara's Avatar
i've bin told by a few mechanics that have i've talked to about my polara and they said there the best engine dodge makes
Old Aug 2, 2009 | 05:06 AM
It was a reman motor with only 5K miles on it. I don't think they were. I just wasn't ready to pull the motor to send it out for that because funds were (and still are) tight.
Old Aug 2, 2009 | 05:08 AM
do the 318 run for a long time?
i have heard that going both ways...
The 318s are one of two motors that Chrysler put out that are realiable. The other is the 225 slant 6. As long as you treat it right, you should never have a problem.
Old Aug 4, 2009 | 02:15 PM
Hey, what about my 440?
72RDRNR
Oct 1, 2012 05:05 PM
68 Fury
Aug 25, 2012 07:39 PM
hmiller79
Jul 25, 2010 03:36 PM
BuckNeccid
Dec 20, 2008 05:51 AM
moparpartz
Jan 28, 2008 10:25 AM
