Help with little bitty screws
Guest
Posts: n/a
Hi Folks,
I'm probably the first person do do such a dumb thing, but, when putting new points & a condenser in my 1966 225 slant-6, I managed to drop both of the little screws needed to mount those parts.
My local parts stores pretty much suggested buying a new car.
Can anyone help me with what size and where I might find a couple of screws like that.
Oh yeah, those screws are both different sizes.
Thank you most kindly,
billybenbob
billybenbob
Guest
Posts: n/a
so, are they hiding in the distributor wait to explode the distributor?
you might want to pull the distributor to check. while you're at it change the plastic drive gear as they get brittle when they get old.
they might be 6/32 and 8/32 but if you have the distributor out it's very easy to bring it to a hardware store. they can't be much longer than the plate they go through or it will cause problems.
one other thought is to swap it over to electronic ignition and not have to do this again.
one you've pulled a few distributors, most people find it easier to pull the distributor on a 6 to change the points.
69sixpackbee
08-17-2020 12:37 PM
76NY440_nTX
07-17-2011 07:05 PM
timmymacnj
04-09-2010 08:44 AM
