Help with Tune Up
Old 02-05-2014, 01:14 AM
DL400's Avatar
Help with Tune Up
Hello Everyone,
I am wanting to do a tune up on my 1971 Dodge Charger SE 383 6.3L.
However, not sure what kind of spark plugs or wires to get.
Can anyone recommend? All original.
Thanks!
Old 02-05-2014, 04:55 AM
Mr.4spd's Avatar
Are you going for a stock look or performance? I like Champion plugs cause they're made in the US, but any name brand plug is fine. I use black 8.5mm MSD wires, universal set and then I cut them to fit.
Old 02-05-2014, 07:32 AM
Just buy good parts....
Service And Safety inspection every 3,000 miles
And
Major Service & Tune up every 20,000
Handle the little things in-between...
And
Things will be great
Old 02-05-2014, 09:09 AM
Stick with conventional Champion, autolite, NGK, none of the Bosch platium and such.
Good quality wire! Do you have headers ? Wire routing is critical if you don't want to burn plug wires
Old 02-05-2014, 09:54 PM
DL400's Avatar
Thanks for all the responses!
Would like to go performance route for plugs and planning on getting MSD wires.
No headers.
Old 02-05-2014, 10:47 PM
DL400's Avatar
Thoughts on Mallory Pro sidewinder wires?
Old 02-06-2014, 10:36 AM
Mallory makes good stuff also..
Old 02-08-2014, 05:21 PM
70newport's Avatar
the msd kit where you make your own wires is what I use currently. I love that I got to choose length and could add in a few "wire clips" to hold them in place where I want them to be.
DO NOT BUY E3 spark plugs. I wasted my money on them. they were awful. Especially seeing as they were about $40 more for the set.
Old 02-08-2014, 05:34 PM
Mr.4spd's Avatar
I've never tried them. Were they awful because they were expensive and no better than the rest?
Old 02-08-2014, 06:55 PM
PURPLE HORONET's Avatar
The best bang for the buck on a mild engine is Belden plug wires from Napa
Old 02-09-2014, 07:48 AM
I also like Accel Super Stock 8MM Wires,,
Old 02-11-2014, 08:03 PM
70newport's Avatar
With not being able to gap them I found that my throttle response was terrible and my mileage was worse than usual. I spent a bunch of time retuning the carb and couldnt get it resolved. As soon as I swapped back to a $4 champion plugs my car ran like a top again.
Just my experience.
Old 02-11-2014, 08:35 PM
Hummmm..... I have the worst luck with Champions...
Clevdog24
09-29-2012 09:46 AM
Nomadci
04-01-2011 04:50 AM
auerdoan
10-29-2010 09:40 PM
CantRamItDodgeIt91
11-16-2009 07:26 PM
67Polara
08-03-2009 12:39 AM
Quick Reply: Help with Tune Up
