Hydraulic Fluid in Trans....?
Old 05-22-2012 | 08:15 PM
Dartingtraffic's Avatar
When I bought my dart the guy said there is hyd. fluid in the tranny, and thats the only fluid to run in it? Its an auto. I have never heard of this....can someone please explain this.
thanks - Brandon
Old 05-22-2012 | 08:58 PM
MrOldart2U's Avatar
Ummm no i cant explain it, and I am not for sure hyd fluid would work or give good service.... but i am no oil specialist, nor trans guy.... I would pull the stick and check it for color, MOST hyd fluids are clearish....
Old 05-22-2012 | 09:47 PM
Mr.Duster's Avatar
what kind of tranny is it? i never heard of that either if he did put that in its a wonder its not messed up by now
Old 05-23-2012 | 03:55 AM
There are a bunch of different hydraulic fluids (different viscosities) out there so the PO would have to explain exactly which one he used. I have never heard about putting hydraulic fluid into an automatic.
Are you having any drivability issues with it? If so, then I would suggest pulling the tranny, tearing it all apart and cleaning everything. If no drivability issues, then take it to a good tranny shop and ask them to perform a tranny flush and have regular ATF put in.
Old 05-23-2012 | 09:45 AM
A trans flush can sometimes do more harm than good. I would drop the pan and change the fluid AND the filter.
Old 05-23-2012 | 03:14 PM
727 auto. I havent had any issues yet. Once it warms up it shifts great. I am though going to bring it to a specialist to flush and fill with the rite fluid!!!
Also do you guys know how I can go about on finding the previous owners of my dart?
Old 05-23-2012 | 05:53 PM
Maybe the guy doesn't know what he's talking about. ATF IS A FORM of "hydraulic fluid."
What color is it? What does it smell like?
Old 05-23-2012 | 06:52 PM
PK1's Avatar
PK1
My former mentor still calls all automatics "hydromatics" and transmission fluid "hydraulic fluid".
I know there are additives and seal conditioners in all the different tranny fluids per application but man.... ATF4 is NOT cheap!!!! I wish they took hydraulic fluid.
Old 05-29-2012 | 05:12 PM
Gorts 5th's Avatar
sounds like its a old tranny and has wat we call hard seals the seals are hard and dont seal so the clutches dont have enough pressure a old trick was to put hydro fluid in the tranny its thicker viscosity was a way to prolong the inevitable.
Gorts 5th
10-31-2013 06:35 PM
DonRobs
09-23-2013 04:52 AM
q8_barracuda
12-30-2011 05:30 PM
1cerberus4u
04-18-2008 07:55 PM
62sportsweep
04-07-2008 04:38 PM
