Intake Manifold and Carburater Set up???
Old 08-03-2009 | 12:51 PM
68 Sat's Avatar
Guys I have to replace the intake and carburater set up on my recently acquired 440. It has 413 heads and is a stock 1978 casting. I was looking at the edelbrock dual plane intake with a 750. Any suggestions/comments would be helpful.
I'm building a street performer and just want reliability with moderate performance.
Old 08-03-2009 | 02:17 PM
I'd get an Edelbrock performer carb to go with that intake. Sounds like a good choice to me.
Old 08-04-2009 | 02:07 PM
i'd personally put an 800 on it
Old 08-04-2009 | 06:58 PM
68 Sat's Avatar
I found a cc to ci formula on-line and it states a 700 should be max. What should I know about carb size to cubic inch ratios?
Old 08-05-2009 | 08:01 AM
68 Sat's Avatar
thanks...point taken
QUICK QUESTION
Summit has many edelbrock dual plane maqnifolds of variuos prices. What should I be looking for?
Old 08-05-2009 | 08:33 AM
72RDRNR's Avatar
With a fairly stock build I would go with the Performer RPM and an edelbrock 1411 carb. Only thing about the performer rpm is its a highrise so might run ito problems with hood clearance. Drop down aircleaner might hit the electric choke (maybe go without the electric choke). They give all the measurments on the website so might need to double check them.
Old 08-05-2009 | 04:32 PM
make sure your hood clears like they said
try putting something that'll squish easily on the air cleaner, then shut the hood, and see what happens
newto440
24
04-23-2014 06:32 AM
Tunedportz
11-16-2010 06:52 PM
Nipples
08-01-2010 03:36 PM
M1 Manifold
05-21-2009 02:23 PM
Liu Kang
01-25-2009 05:50 PM
Quick Reply: Intake Manifold and Carburater Set up???
