My 318 Build Thead :)
Old Feb 22, 2012 | 04:05 PM
I blew the 318 in my ’68 Fury quite a while back, and I finally have some and time to put into it. I have never done a build thread, so I figured it’s about time I started one.
The engine coming out of the patient:
I opted to take the tranny out with the engine because I’ll likely freshen it up, too, funds allowing. I know the 727 is bullet proof and all, but better safe than sorry. I’d hate for it to all have to come back out again.
Finally got the engine on the stand. It was sort of a debacle because I had constructed the engine stand backward on accident. When we tried to drop the 318 down, the engine stand buckled and we couldn’t figure out why. By the time my buddy noticed my error, I had welded on it and... oh, it wasn’t fun.
Here’s the 318 before we shot it with two cans of de-greaser and took the power washer to it. 350,000 miles of road grime was a challenge.
I’d had a couple beers by this time and decided to try and get artsy with the camera. The shots actually came out pretty cool! Bath time for the little engine.
Old Feb 22, 2012 | 04:06 PM
Here is the 318 starting to come apart. My buddy needed a little more engineering fluid, so I was able to pause for a shot.
There was definitely more than a few hard miles on this one.
My buddy working on the front pulleys.
I know for a fact the timing had jumped at least a tooth because a gun was useless. I had to time the thing by ear and feel, which hastened the 318’s demise. This is why 20 year old kids shouldn’t be driving cool cars. :P
Almost time to see what the heck happened when I lost all oil pressure and heard a deep, hard, knocking sound. I figured I had spun a bearing when the oil pump went, but that wasn’t the half of it.
Everything looking okay at first glance. Not great, but nothing deadly.
Then the monster showed itself. I was right with my diagnosis: The engine had lost its oil pump, and I had spun not one or two, but THREE bearings. They all looked like this one.
Due to the damage the bearings did to the crank, I’ll have to have it turned for sure. You can see on the right there, the grooves that are present. That won’t get me ten miles on a rebuild.
The engine itself is going to be a little hot, and *should* net me around 330 horsepower, at least on paper. Here’s the build list:
.030 over pistons
Port heads and add 2.02/1.60 (or 1.88/1.60) valves
Install the Comp Cams 256, built for low and mid-range torque. Nothing wild. It’s not a racer, it’s a cruiser. I just wanted some more thump.
Edelbrock manifold and either the Holley that was on it before or something by Carter. Either way, probably 650cfm.
Cheap headers from Summit.
The rest will be just basically putting it back together and hoping it all spins at the end of the day. This definitely won’t be your average 318, and I’m eager to see what it does from a stoplight. Stock #s were 230 HP and 340 torque, so I’m expecting a fun little engine, here.
I’m going to keep the freeway flyer gears and all that. The car likely won’t ever see the other side of the 1320; I just wanted a street cruiser with some get-up-and-go.
Old Feb 22, 2012 | 08:01 PM
Good job posting so far. Just be careful with the night work and those PBR quarts. Oil pumps going out seem to tear things up. Like the pictures keep them comming.
Old Feb 22, 2012 | 08:06 PM
Yea, beer for the take-down only.
All engine build work will be with water in hand.
Thanks!
Old Feb 24, 2012 | 01:42 AM
Valle6062's Avatar
2.02/1.60 valves in 318
.030 over pistons
Just remember to notch your cylinders for the space the 2.02/1.60 valves needs to fit. I did in in my 273 and it works just fine
Old Feb 24, 2012 | 11:26 AM
Nice! What are the specs of your 273?
Old Feb 24, 2012 | 02:31 PM
Valle6062's Avatar
1964 273cui, 340HP camshaft, 1972 318 heads ported with 2,02/1,60 stanless steel valves, Airgap intake "made in china", true roller cam chain, Hei dist "made in china", Edelbrook 650, sounds good
http://www.youtube.com/watch?v=eWHCS...G5XucE4X5-Ngag
Old Feb 24, 2012 | 02:34 PM
Right on! That does sound really nice! I'll bet that's a punchy little engine. Scare a few Chevy guys with it?
Did you put it all together yourself? This is my first V8 build.
Old Feb 24, 2012 | 11:58 PM
Valle6062's Avatar
Question
Well, I haven´t drive it more than 15km on the road yet, because there is no interior in it yet, But when I moved it for the wintersleep last year there was 2 black stripes on the road behind me:-D,
Right now it hangs in the garage and there is a lot of weldingjob on it, then I´ll put an interior from a BMW 750i 1995, Black skinn, powerseat both in the front and back. My thougt was that why shouldn´t I sit good just because my car i 50 years old
In this summer or next? I will go and test in on a rolling highway "testbench" but my guess is that i will have around 300hp on my backwheel...
Yes I have made the work by myself, except for the heads, they where made by a guy that worked as a pro machinist for 40year....
Old Feb 25, 2012 | 12:06 AM
That is awesome. Kudos for your hard work.
Old Mar 2, 2012 | 02:58 PM
PK1's Avatar
PK1
Good call on those seats! Heated and POWER! I have done similar and the comfort of a quality OEM seat was NICE... Post pics when done..
Old Mar 2, 2012 | 05:02 PM
Personally with the small cylinders I would keep the stock valves on a 318. 2.02 valve will not make much difference unless your turning 5K + RPM. Use a good dual plane manifold and a 600 cfm carb, headers and some 0 deck pistons to raise the compression
Old Mar 2, 2012 | 05:04 PM
Yea, I don't think I'll go as big as 2.02, but bigger valves definitely help the flow. The heads on a 318 are the weak point anyhow. All these decisions are killing me, lol. I just want a mildly stout 318 that'll be reliable.
benjy1234
Mar 8, 2015 03:58 PM
ibstewrat
Sep 30, 2011 10:40 PM
The Creed
22
May 29, 2011 02:17 PM
74roadrunner
Mar 19, 2008 05:23 PM
73DartSport
Mar 6, 2008 04:02 PM
