Need brake help PLEASE
Old Mar 25, 2012 | 03:15 PM
general 01's Avatar
I have a 70 charger with manual front dics brakes, afew weeks ago the brakes started grabbing pulling hard to right. Calipers not releaseing I checked with afew guys at the auto parts store and they all said I needed to change my calipers, because they were sticking, Well I did that today and THE NEW ONES STILL STICK!!! It locks up the front I have to open the breeder value to get them to release. Can ANYONE tell me what else to change? Can't drive it like this.....
Old Mar 25, 2012 | 05:36 PM
dartcuda's Avatar
Smile Need brake help PLEASE
Sounds like tour brake hoses are collapsing on the inside.Re place your brake hoses and you should alright. Mark
Old Mar 25, 2012 | 06:34 PM
fivepoint's Avatar
If both calipers are not releasing, I would be looking at the master cyl. Make sure pedal linkage is lubed and free. The piston in your master cyl may not be returning to the fully released position.
Old Mar 25, 2012 | 07:35 PM
dartcuda's Avatar
When he opens the bleeder the calipers release,That is a sure sign of bad brake hoses.The fluid is going one way and not returning back to the master cylinder because of the brake hoses.I just had this problem with someones car and won a lot money from it. Mark
Old Mar 25, 2012 | 08:02 PM
That's the reason why someone started making the stainless steel flexable front brake lines.
Old Mar 25, 2012 | 08:20 PM
The fluid return port in the master cyl could be clogged too... especially since both sides are sticking
Old Mar 29, 2012 | 08:14 PM
dartcuda's Avatar
what is a fluid return port
Old Mar 29, 2012 | 08:22 PM
B.Northway's Avatar
had happen to 3 vehicles change your brake line its rotted inside n collapsing every time you compress the calliper therefore locking up. We went through 3 calipers before we figured it out! good luck
Old Mar 29, 2012 | 08:25 PM
B.Northway's Avatar
change brake line
went through 3 calipers to find out it was only a bad break line rotted n collapsing on the inside therefore locking up the caliper
Old Apr 8, 2012 | 05:03 PM
dartcuda's Avatar
Gerenal 01 just wanted to know how you made out. Mark
73plymduster
Aug 15, 2010 10:21 AM
Charger 01
Jul 30, 2010 06:48 PM
DUST360
Oct 11, 2009 09:54 AM
89lebarondriftR
Jan 14, 2009 05:25 PM
hlfishman
Jan 12, 2009 05:40 PM
