PLEASE HELP traction bars problems
Old Sep 20, 2011 | 01:40 PM
scotty's Avatar
Unhappy PLEASE HELP traction bars problems
this may sound stupid ,but i bought some universal Lakewood traction bars,and im wondering if ive installed them right?i have the back u bolts tightly bolted down to the leaf spring behind the axle but are the front ones suposta be the same or free floating a bit,,if i tighten them all the way down i will need to pretty much remove the snubber,,lol,
Old Sep 20, 2011 | 03:04 PM
Should have saved your money and bought some Super Stock Springs. Traction bars are for Chevys. Yes there should be an air gap in the front
Old Sep 20, 2011 | 04:07 PM
mr340's Avatar
If you removed them from the box and attached them to a Mopar........NO! They won't really do much for you except draw some attention to the yellow paint under the car.
Old Sep 20, 2011 | 04:12 PM
The bolts must be tight, to get that gap between the spring and snubber you'll need some spring perch angle shims.
Old Sep 20, 2011 | 06:01 PM
scotts74birds's Avatar
Sorry, Mopar leafs are set-up in a different function than the old chebys. Mopars dont NEED traction bars! Have you heard of a "pinion snubber".
Old Sep 20, 2011 | 07:02 PM
Archer's Avatar
scotty -
I've been running traction bars similar to the Lakewoods since the late 70's on my Charger. Yes, they work and will limit spring travel on launch (just do a few launches with and without them and see for yourself). They also stiffen the springs somewhat. Both front and rear bolts or brackets need to locked down and you do need some gap between the bumper and the leaf eye. 1/2" is about average, but there's some trail and error required.
Old Sep 21, 2011 | 06:45 AM
scotty's Avatar
thanks everyone for the help,,BTW there not yellow ,,i got CHROME
Old Sep 21, 2011 | 09:37 AM
BLING BLING!
Old Sep 21, 2011 | 01:00 PM
Archer's Avatar
Scotty / Tim -
Black gives them more of a stealthy look...
Old Sep 21, 2011 | 01:51 PM
MercuryDon's Avatar
Traction bars are designed to stop wheel hop. They will do that job well if correctly installed. If your not suffering from wheel hop you won't see much if any differance other than a stiffer ride.
Old Sep 21, 2011 | 04:08 PM
mr340's Avatar
Been so long since I owned a Chevy, I didn't realize they came in chrome now....
Old Sep 22, 2011 | 06:43 AM
scotty's Avatar
mine look like yours archer
xvodysseusvx
Jun 25, 2018 04:38 PM
mack23
Jul 13, 2015 10:35 PM
mslisaj
Sep 24, 2014 08:14 AM
1968newport
17
Dec 22, 2013 02:04 PM
scampdude
Feb 10, 2011 03:15 AM
