Special Tool's ? Fuel Line
Old Aug 13, 2009 | 05:03 AM
OutlawCuda's Avatar
Senior Member
Looking for some expert advice, I am in the process of doing a tune up on the wife's 1993 Chrysler and have run into a snag with the fitting's in the fuel filter. Do you have a favorite tool you use to release the fitting? I looked in the factory manual and it's not much help. There isn't much space between the filter and the fitting.
Thank You OutlawCuda
Old Aug 13, 2009 | 05:56 AM
Is it a plastic clip or just a brass fitting? I like to use PB Blaster on them and then use a flare wrench as they are less likely to round the fitting off.
Old Aug 13, 2009 | 06:10 AM
OutlawCuda's Avatar
Senior Member
Metal fitting With a Plastic clip inside
Thank You for your help,Its a metal outside with a plastic inside nasty little thing!!!
Old Aug 13, 2009 | 06:39 AM
johnthegoalie's Avatar
thinkin with me dipstick
checker has them - a/c anf fuel line quick disconnect tool
look like this. careful with the pressurized fuel...
Old Aug 13, 2009 | 08:48 AM
I have a set of those. They are great! You need them to disconnect that fuel line that you have. They are not that much $$$ and can be picked up at almost any parts store.
Old Aug 13, 2009 | 10:26 AM
OutlawCuda's Avatar
Senior Member
Hack Saw
Thank You for all your advice, the release tool was the way to go until I got to the outlet of the filter. I should have posted a picture, There was no room to get the tool in between the filter and the fitting. There was about a 1/4" of space at the most. Looked at it and after a while I decided to use the hack saw. Not my first choice but thats all that would cut the stainless tube. I put grease around the fitting to reduce the chance of a spark I think !!! Got 2 big fire extingwishers put on my fire suit and a nomex hood from the race suit . I wasnt going to take any chances. LOL Then I cut the tube of the filter and insterted a self tapping screw in the short stub of the tube, inserted the release tool and off it came. Never did see a spark but I had a close friend have a trouble light fall and break when they were repairing a fuel line. To this day all that is left is the concreat slab where a beautiful shop once stood. Have a Great Afternoon and Thank's again.
OutlawCuda
Coating Methods
Sep 26, 2011 05:17 PM
Ellis Wyatt
Jan 15, 2011 02:16 PM
mitchs66
Sep 4, 2009 10:51 AM
nesparky
Jun 2, 2009 11:43 PM
dboland
Sep 2, 2008 03:59 PM
