using a pearl base coat
Old Jul 7, 2009 | 04:10 PM
theomahamoparguy's Avatar
Originally Posted by cudanut476
I am painting all of the door jams/engine bay/decklid for my 1970 cuda myself so I can save some money in a full paint job. I am using a color called plum pearl metallic from summit racing. I was wondering if I had to use a certain type of primer for my paint. Also, when mixing 4:1 in the plastic measuring container do I use the 4:1:1 column and fill the color up to the first 4, then the activator to the second 4? Since I'm using a peral I don't want to mess anything up.
thanks, Jim
It would seem like it would be 4 parts paint, 1 part reducer and 1 part activator to come up with the 4:1:1 ratio. Id call summit and speak to someone. Im pretty sure summit sells the primer too but it may work with other primers. I read about that summit brand paint.{really good deal} just cant remember the specifics. The mixing cups should be somewhat self explanatory. I believe that there are 2 or 3 columns next to each other for each of the different mix combinations. You fill the paint up to one line and then you fill the reducer up to a line in the next column that corresponds with the mix ratio and so on for the next column [activator].
mystarcollectorcar.com
Oct 22, 2010 04:52 PM
CaboChallenger
Aug 23, 2010 03:00 PM
rcknrolfender79
Feb 18, 2010 05:56 PM
MarkyMark12345
May 10, 2009 01:25 AM
1 Bad Mirada
Feb 18, 2009 05:57 AM
