‘16 Challenger turn signal
Old Sep 27, 2023 | 11:01 PM
Zweik's Avatar
I have a 2016 Challenger SXT. The FR turn signal went out with a message on the dash. It flickered a bit but now doesn’t work at all. The FR DRL doesn’t work either. Both lights only work when I lock the car from the key fob. Where do I start to diagnose the issue. Thanks
Old Sep 28, 2023 | 04:49 AM
Kuvasz101's Avatar
Always start with bulbs first. I know you said they're working but it shouldn't be overlooked. Try emergency flashers. If they work the bulbs are good. Emergency flasher and turn signal flasher are different. It could be the flasher.
Old Sep 28, 2023 | 11:34 AM
Zweik's Avatar
mine has the orange led halo. They’re not bulbs. When I turn the hazards on, only the left side works. The FR only works when I lock the car from the key fob
Old Sep 28, 2023 | 01:16 PM
Kuvasz101's Avatar
Gotcha!! Old schooler here. I should've known, I owned one for 11 years. Could you get a test light in there and see if there's power and if not trace it back.
Old Sep 28, 2023 | 02:36 PM
Check the fuse and also check the ground and make sure it is good....
vroc4507
Oct 1, 2022 07:06 AM
lmader
Aug 29, 2022 05:01 PM
chykov's76doba
Oct 29, 2014 03:08 PM
brent b
Jul 22, 2014 02:04 PM
nesparky
Dec 12, 2011 07:05 PM
