1965 Plymouth Satellite Lower Control Arm
Old Jun 16, 2009 | 05:18 PM
stanhope55's Avatar
Member
I am planning to install a sway bar on my car and will have to change out the lower control arms as you know...... can someone tell me the model years compatible for this swap..... would any B bodies till 73 work ?
Thanks
Old Jun 16, 2009 | 07:18 PM
Is this an aftermarket swaybar or factory?
Old Jun 16, 2009 | 08:35 PM
theomahamoparguy's Avatar
I am about 90% sure that the '66 -'70 ('71 or '72??) or any E body lower control arm should have the same dimensions as your '65 Ply. Thr only problem I can see is the front mounting points of the sway bars. I assume you are going to use a later style swaybar [like for a 69 B-body.] Hopefully someone else can shed some light on this subject. Has anybody retrofitted a sway bar to a pre '66 B-body?
Old Jun 17, 2009 | 04:26 AM
stanhope55's Avatar
Member
It will be aftermarket, then I heard that PST (think that's the name) has a kit that will allow me to use my original lower control arm that has a clip which bolts on to the shock mount for easy install ?
Heard of this anyone ? Good or bad idea ? strong enough ?
Thanks
Old Jun 18, 2009 | 07:50 PM
Thanks
yEAH, I know someone that has that setup on a 64 B body.
Says that it works great with his bigblock.
Old Jun 19, 2009 | 02:04 AM
I'm not to keen on "clips" but depending on the size of them, it should be good.
Inspector71
Oct 15, 2013 01:26 PM
Oneder07
Mar 18, 2011 02:18 AM
mytracy
Dec 22, 2010 06:24 AM
80VDuster
Aug 18, 2009 05:37 AM
upnorth52
Oct 23, 2008 09:07 PM
