318 in need of power
Old Aug 7, 2009 | 08:15 AM
jsbeast's Avatar
Junior Member
how can i get the most power out of my 5.2?
Old Aug 7, 2009 | 03:53 PM
what car is it going in?
Old Aug 7, 2009 | 04:27 PM
jsbeast's Avatar
Junior Member
85 Ramcharger 4X4
Old Aug 7, 2009 | 07:17 PM
well, stat with the intake
edelbrock is best for mopars
then move onto a cam that'll give you some low end power to move that car
then onto heads
try PM'ing Valcam
he just finish building a very powerful 318
Old Aug 7, 2009 | 08:30 PM
What is the vehicle used for?
From there we can let you know what we think is best for it.
Old Aug 10, 2009 | 03:28 PM
deadkelly's Avatar
the old 318 really needs some compression
but if its just cheap bolt on power that's easy .
new petrol , oil filter & air filter & oil change , new spark plugs , hi voltage coil , replace leads if they look old & dirty & any cracks . fuel system cleaner / carby cleaner . start there .
Old Aug 10, 2009 | 04:42 PM
deadkelly's Avatar
if you want to go a bit deeper into it .
find 2nd hand extractors / headers & free flowing mufflers it will sound better also . talk to an exhaust shop & plumb up your breather tubes from your tappet covers to your extractor collectors . that will give you more ring seal & better compression over 3000 rpm = more power .
look out for a 2nd hand dual plane alloy manifold & carby spacer , the one with 4 holes might help you .
i like msd 6al or other ignition boosters you may as well burn the air fuel mix properly . on that note do you have a electronic dizy ? if not they will help . there are some cheap dizy - ignition kits around these days .
HEADS a good clean , fresh valve job , new valve stem seals , new .020'' head gaskets , 360 aftermarket inlet valve with flat faced valve for more flow & more compression . or back cut std valves & bowl port job & deshroud you valves .
power is in your heads that's where you spend your money !!
i don't know how much money your thinking of spending ? if you on a very tight budget then its prolly just one thing at a time . if moneys not a problem a crate 360 might be the go . if you have money & really love your 318 well the sky's the limit & then it gets really fun .
when it comes to buying a cam make shore you buy one that suits your combination . buy a cam that suits your heads , compression & carb & what you'll be doing with it .
MAGNUM GT XS22L9R
Mar 9, 2021 06:33 PM
jpnavy
Feb 7, 2010 09:13 AM
mahd
Feb 5, 2009 01:34 PM
tyler1
Oct 25, 2008 10:17 AM
mopar528dakota
May 11, 2008 12:56 PM
