From the rear of the motor ? I would check the inspection plate for the trans. See if the flex plate bolts are hitting and that you have the correct type bolts
there's about a 1 inch gap between the plate and trans housing,and its missing the bottom two bolts! i would of never looked down there! smh this blows
