4 speed Conversion
4 speed Conversion
I want to convert my Cordoba from a auto to a 4 speed. I will be going to a 400 or a 440 at a later date,but I want this to be my first mod to my car.
I know this will be a lot of work. What do I need to get excatly for this swap and the best way to do it?
I know I need to get flywheel,clutch pressure plate, pilot bearing, bell housing,4 speed trans,Z bar,pedals. I know I am missing some parts to get.
I'm pretty sure you'll have to put a new tunnel in it. Make sure you make it to fit a BB bellhousing so you don't have to do it twice. If they didn't come with a manual you'll have to fabricate a tranny mount and crossmember.
Will the angle of the trans be set by the engine or will I need to figure that part out?
good article explaining pinion angle. http://www.hotrodheaven.com/tech/cha...ngineangle.htm
this is for a bodies, but it is very similar.
http://www.bigblockdart.com/techpages/4sptech.shtml
Thanks I will read it.
