4 speed Conversion
Old Jan 2, 2010 | 10:58 AM
old tired rebel's Avatar
4 speed Conversion
I want to convert my Cordoba from a auto to a 4 speed. I will be going to a 400 or a 440 at a later date,but I want this to be my first mod to my car.
I know this will be a lot of work. What do I need to get excatly for this swap and the best way to do it?
I know I need to get flywheel,clutch pressure plate, pilot bearing, bell housing,4 speed trans,Z bar,pedals. I know I am missing some parts to get.
Old Jan 2, 2010 | 01:31 PM
toad490's Avatar
I'm pretty sure you'll have to put a new tunnel in it. Make sure you make it to fit a BB bellhousing so you don't have to do it twice. If they didn't come with a manual you'll have to fabricate a tranny mount and crossmember.
Old Jan 2, 2010 | 01:42 PM
scotts74birds's Avatar
I'd recommend looking at a hydraulic clutch pedal and throwout bearing assembly.
Old Jan 2, 2010 | 02:03 PM
Thanks I will do that. I figure I would have to make a crossmember and have a driveshaft made.
Great idea less moving parts.
Will the angle of the trans be set by the engine or will I need to figure that part out?
Old Jan 2, 2010 | 02:41 PM
good article explaining pinion angle. http://www.hotrodheaven.com/tech/cha...ngineangle.htm
Old Jan 2, 2010 | 05:08 PM
Thanks that was a good read.
Old Jan 2, 2010 | 08:00 PM
johnthegoalie's Avatar
thinkin with me dipstick
this is for a bodies, but it is very similar.
http://www.bigblockdart.com/techpages/4sptech.shtml
Old Jan 2, 2010 | 08:02 PM
Thanks I will read it.
Old Jan 2, 2010 | 09:24 PM
if you have all the parts ahead of time it isnt that bad to convert, i did mine in a weekend
Mchury
Apr 6, 2013 12:35 PM
lvin4jc
Mar 28, 2011 10:49 AM
70bee
May 30, 2009 11:21 AM
joel
Feb 22, 2009 07:07 PM
BTKBraden
Feb 22, 2007 11:31 AM
