57 dodge interchange?
Old Nov 10, 2010 | 05:53 AM
mopar 69's Avatar
Question 57 dodge interchange?
can anyone tell me if a 57 d500 cab from a ton truck would be same as a d100 half ton, and what other body parts are the same?
Old Nov 10, 2010 | 07:13 AM
A 1957 D500 was a car. The truck D-series was not started til ~1961 til 1993.
The 1-ton 2wd truck was called a D300/D350 (later years). Most of the 4wd and 2wd cabs were interchangeable as long as the they were in the same generations.
Old Nov 10, 2010 | 07:18 AM
mopar 69's Avatar
oh ok i was told it a d500 truck but it is a ton or larger. cab and hood i thought were same as half ton?
Old Nov 10, 2010 | 07:23 AM
Dodge did make a D500 truck but it is not the same as the D100-D350 trucks. The D500 and up trucks were more of a commercial truck (heavy duty). They D100-D350 trucks were light-medium duty that normal people would buy and use.
Old Nov 10, 2010 | 07:29 AM
mopar 69's Avatar
this is a large ton or mabe 2 ton has duel wheels in rear and larger wheel wells in front fenders i want to build a 57 half ton but cant find any, thought i mite start with this cab?
Old Nov 10, 2010 | 07:45 AM
mopar 69's Avatar
I did alittle searching, think what i found is a 57 w500, would the cab be the same as a half ton
Old Nov 10, 2010 | 08:50 AM
The W500 is actually a 2 ton chassis and cab truck. It is just as different from the D100-D350 cabs. The issue is that the chassis will differe from generation to generation. Because of this, the cab mounts will change. If you are good with measurements and fabricating, you can make anything fit. What you have and what you want to put on (from my understanding) will not be a direct bolt on though. You will need to move and shim some, if not all, of the mounts to get it to fit properly.
Do you have any pics?
Old Nov 10, 2010 | 07:13 PM
Silverick's Avatar
I found this link. If you scroll down the page, there is a nice blue 1957 Dodge D500 flatbed truck.
http://www.hankstruckpictures.com/br...07_vintage.htm
I also found this link. Same thing if you scroll down, there are some sweet '56 and '57 Dodge D100 trucks.
http://oldcarandtruckpictures.com/Pi...950-1959a.html
I used to drive a '54 D100 with a poly 318 and a granny 4 speed (no synchro into 1st or 2nd) and personally, I think that the actual cabs are the same for the D500 and D100s.
The chassis, suspension and fenders may be different.
The one that I drove was 6 volt, the battery was under the driver's side floorboard and it only had one taillight as that's all that was required.
Old Nov 11, 2010 | 02:59 AM
The sweptside is labelled wrong I think. He has it labelled as a "D" when it should be a "C".
I've got some books at home that talk about the history of dodge. I'll try and go through them over the next couple of nights and see what I can dig up.
destro360
May 3, 2011 05:51 PM
gl440
Jun 18, 2010 08:46 AM
MoparMan76
Apr 3, 2010 03:20 PM
Polara_68
Apr 17, 2009 07:48 PM
ramhead
Sep 11, 2008 07:57 PM
