67 d100
Old Nov 20, 2012 | 03:19 AM
fury_19's Avatar
67 d100
hey just looking for some opinions/warnings pics will fallow.
my uncle has a 67 d100 fleet side. it was running when it was parked
supposedly a solid body no real rust dammage
318 possibly bigger engine
but it has a "locked" front wheel as he says.
let me know what you guys think im just wanting it for the looks and what i hope is old mopar reliability that keeps running. any input would help thanks
Old Nov 20, 2012 | 05:08 AM
62Furious's Avatar
Take the tire off and pull the drum off, the brakes will probably come apart, cut the drum put new shoes on and make sure the adjuster is free, put it together,and let it roll
Old Nov 20, 2012 | 08:27 AM
fury_19's Avatar
Any opinions on a scarebird conversion kit for the front brakes?
Old Nov 20, 2012 | 09:11 AM
You could always see if a later D-series front knuckle will bolt on. If it does, then you can swap over to disc using that.
Old Nov 20, 2012 | 09:40 AM
Chryco Psycho's Avatar
scarebird is a good product & uses readily available parts for the conversion
Old Nov 20, 2012 | 11:22 AM
If the wheel is locked It could be several possibilities. Bad master -not allowing fluid to return, frozen wheel cylinder, collapsed rubber brake hose. It could also be a frozen wheel bearing.
Not sure on conversion, I think you still have the I beam suspension which limits options
Old Nov 20, 2012 | 01:22 PM
fury_19's Avatar
well i looked at IFS kits... pricey, around 2000 to 3000 for everything which long term seems like a good idea and a smoother ride...
but the scare bird for the price and amount of work seems like the better choice starting out.i think my kit was going to be 175$
at any rate before we trail off too far... im still waiting on the photos and apparently its full of red wasps at the moment... says the stir up every time he mows around it lol.
so brakes are an issue, not sure in the engine yet, body should be good... what about the gas tank though? i've never had an in cab one.
any known issues? like with fuel pumps or leaks in the cab?
Old Nov 20, 2012 | 01:24 PM
fury_19's Avatar
did they make a 2wd with front disks and an I beam in the front?
Old Nov 21, 2012 | 02:20 AM
I don't believe they did. I was thinking they had IFS at that time for the trucks.
Old Nov 22, 2012 | 06:23 AM
fury_19's Avatar
pics are in the album i got to get a photo bucket account to post them in a thread... in progress
chlngr1970
Sep 30, 2010 08:54 AM
33harner
Jun 28, 2009 10:56 PM
33harner
Jun 7, 2009 11:18 AM
mopard100
Oct 6, 2008 02:38 PM
chlngr1970
Aug 1, 2008 09:26 PM
