69 Dart Engine Swap
69 Dart Engine Swap
Hey guys,
I,m replacing my slant 6 for a V8, and I found a 73 Coronet with a 318 as a donor car for $500.
What else would I be able to use from the coronet, besides the engine, tranny and radiator? What about rear end? Front discs? Anything else?
TKS
TKS
Why do you want to pull the 6 out? You will need to find a short tailshaft 727 and you may be able to use the rear end, you'll just have to move the perches probably. I would take some measurments first though.
Guest
Posts: n/a
x2 on the trany dont matter the length it will work driveline may not. same with the rear end measure twice. well thats not a bad buy 318 is a good engine. can even get good power out of it. you should be able to sell some parts off of the donnor and put some
in you pocket.
in you pocket.
