904 Fitment
Old Jun 28, 2009 | 09:12 PM
jar84203's Avatar
Member
904 Fitment
I've got a 66 Dodge Coronet with a 318 Poly and 904 trans. My question is will the trans bolt up to a big block, or would a different trans be needed? Thanks in advance.
Old Jun 29, 2009 | 01:43 AM
You will want/have to bolt up a different tranny. While the 904 tranny is a good tranny, it won't last long behind a big block. Plus you would need an adpator housing to make it work. You would be better off finding a 727 big block tranny out of an RV.
Old Jun 29, 2009 | 09:11 AM
jar84203's Avatar
Member
With a 727 out of a RV need different gears? And where would I find them?
Old Jun 29, 2009 | 11:42 AM
Crazy4Carz.Com's Avatar
No need to swap gears unless you want to.
Old Jun 29, 2009 | 11:59 AM
jar84203's Avatar
Member
So the gears are different? Would you happen to know the ratios of both off hand? Thanks, I'm new at this.
Old Jun 29, 2009 | 01:25 PM
Nah, the trans gearing is the same.
Old Jun 29, 2009 | 04:31 PM
craveman's Avatar
Senior Member
i guess some of the rv's had a bigger first gear for more torque. i think it was a factory option though inside of the 727. i was going to buy a 440 and a 727 but the guy said it had the optional 1st gear so it would suck in a car
Old Jul 4, 2009 | 07:55 AM
Mopar_71's Avatar
I agree with the 727 trans. It was made for HD small blocks and all big blocks. Except the hemi. It was built different for that application.
The 904 has a small block bell housing and you need a big block housing.
It won't mount to your big block the way it is now.
We are assuming the RV 727 is a A727B.
I have never seen or heard of a lower geared automatic transmission. I'd ask a transmission shop about that. Check the lower left hand side of the bell housing for the family group and the serial number should be located on the drivers side of the oil pan rail.
Another thoughts are you might need to change your driveline yoke becuase of the different splines and the length of the drive line may need to be shortened.
You might need to change your carb to tranny kick down linkage.
There are kits for your motor mounts out there too.
Just throwing out some ideas of what you may be in for.
Let us know how it's going.....
Mopar_71
phtboy03
Jan 6, 2012 11:54 PM
jar84203
Feb 24, 2011 05:16 PM
Kalaek
Oct 28, 2010 06:03 PM
Team Gridlock
Oct 4, 2009 10:09 AM
red79
Jun 6, 2009 11:37 PM
