bearings
Old Jan 1, 2012 | 04:47 PM
willysman69's Avatar
bearings
Need some help again confused on rod bearings. Have 440 and replacing the rod bearings. Checked the rod journal with dial caliper and got 2.375 which I think is standard journal. So I bought a set of standard bearings when I get to taking the old ones off the rods there different some bearings say clevette 77 .001 us and some say DA 49 with a 10-72 on them. When I put the the std bearings on the crank the ends of bearings dont meet theres a gap. The old bearings both ends will touch when I put them on the crank. So what do I have going on. I thought this motor had never been touched do to it having a std bore and metal head gaskets. Any help appreciated
Old Jan 1, 2012 | 05:53 PM
Must be undersized, try again. Don't try and figure it out, I think we all have had improperly packaged bearings.
Old Jan 1, 2012 | 06:29 PM
.010 is ten thousands undersized....Clevite sells bearings for only polished journals at .001.
Sorry but I would never do that..I would turn the crank ten thousands and have the whole assy. balanced.
Old Jan 1, 2012 | 07:23 PM
.001 is ten thousands undersized....Clevite sells bearings for only polished journals at .0001.
So with that being said does that mean that if I show the crank at 2.38 std that the rods could have been machined down at one time and the crank not touched. I will take the crank to a machine shop thanks for your help
Old Jan 1, 2012 | 07:24 PM
First, .001 is ONE THOUSANDTH of an inch. "ten under" would be .01 or .010 "undersized"
Second, don't be depending on a dial caliper to measure cranks. They might be good for a rough check, but not final work. The average back yard guy should become familiar with a product called "Plastigauge"
I would think if you put .001 shells on a standard crank, I would think you'd have trouble seeing that the shells "don't meet." Part of this may be that the shells are "spread" a little bit, IE they won't be in proper shape until torqued into a rod
But if the shells are STAMPED right on the shell .001, they certainly are not standard.
Old Jan 1, 2012 | 07:33 PM
Is it easy to get .001 bearings these days?
Old Jan 2, 2012 | 09:24 AM
http://www.summitracing.com/search/C...0+rod+bearings
And my bad on the decimal places.
Old Jan 24, 2012 | 12:08 AM
The big end of the rod stays the same size regardless of the crank. With what you have ? sounds like the crank has been re sized before. Maybe even from the factory
D100Guy
Nov 2, 2010 07:52 PM
hippo204
Sep 2, 2010 08:17 AM
Bossta
Mar 2, 2010 08:13 PM
Slice
Feb 7, 2010 07:47 AM
pjmopar
May 15, 2009 01:48 PM
