Been getting work done.
Old Jun 21, 2010 | 09:53 PM
RROriginals's Avatar
Well few days ago I started on sanding down the car and priming it, taking it off piece by piece, been raining on and off so I only got the trunk done, hopefully today I can get 2 doors and the hood sanded and primed. Then it's rain for 2 days... I only have a few pics of the sanding process but I'll post some of the primer job and how it all looks after
Half sanded, didn't break the Road Runner badge while prying it off.
Old Jun 21, 2010 | 11:43 PM
1966sportfury's Avatar
A.K.A Bob Dodge
what are you using for primer? also carefull sanding the big flat spots. if you using a da or of that sort you can heat the metal and warp it.
Old Jun 22, 2010 | 03:13 AM
You'll want to go over it with a flat sanding block and 400 grit (minimum) before priming. Also, there is a primer out there (I think Sanels has it) that actually fills in very small sanding scratches. Makes the finished product look very nice. Also, you may want to get some glazing to fill in the little larger scratches.
Old Jun 22, 2010 | 01:00 PM
I'm using an angle grinder with a sanding attachment, it does get very hot, which is why I stop and let it cool every few minutes, so I don't warp anything. I'm using Rustoleum Primer.
Old Jun 22, 2010 | 01:51 PM
A.K.A Bob Dodge
spray can primer???
Old Jun 22, 2010 | 01:56 PM
A.K.A Bob Dodge
if thats what your using your kinda wasting your time and money,
400 is a bit too fine, if your using a da sander go with 180, block sanding 200, then epoxy primer, then primer filler
Old Jun 22, 2010 | 03:06 PM
Had to use spray can primer for the trunk, I'm switching to Paint Shop primer since I got a spray gun and compressor now.
Old Jun 22, 2010 | 03:37 PM
A.K.A Bob Dodge
k kool couse alot pro paints wont stick to spray can primer
cork1958
Jan 17, 2013 02:08 AM
duster996
Jul 15, 2010 03:36 PM
DUST360
Oct 8, 2009 06:48 AM
ef8340
Dec 17, 2008 12:07 AM
