Big Block gas mileage?
Old Oct 8, 2011 | 01:19 PM
  #31
lookingatchargers's Avatar
great info on real life stuff not theortical thanks guys.
Old Oct 8, 2011 | 07:03 PM
  #32
89ram150's Avatar
Ok I'm gonna be the black sheep here with the "newer" truck, but I've been trying to squeeze every mpg I can out of my Ram since it's my daily driver. I have a basically stock (minus all the smog stuff) TBI'd 318, and had a 904 with lockup converter, and either 2.76 or 3.23 rear (~2200 rpm @ 70). Running about 70% city, 30% highway, a/c always on, I was averaging 15 mpg. However I fried that tranny a couple weeks ago and now have a 904 out of a '71 Satellite (non-locking converter). This tranny seems to shift way earlier than my original did, which might be bogging me down a little around town, but I'm hanging in around 13 mpg now.
Old Jul 4, 2012 | 09:55 PM
  #33
SatelliteJosh's Avatar
You guys might've convinced me to get a big block instead of putting my 360 in my Satellite...dad's gonna be pissed hahaha
Old Jul 4, 2012 | 10:24 PM
  #34
Have you considered an overdrive 5 speed ????
But along those lines my brother in law had a 3/4t 70's Chevy
PU he improver the gas mileage by swapping the 350 for a 396 Didn't have to work as hard
Old Jul 4, 2012 | 10:29 PM
  #35
). This tranny seems to shift way earlier than my original did, which might be bogging me down a little around town, but I'm hanging in around 13 mpg now.[/QUOTE]
Adjust the throttle pressure linkage
I had a 68 T&C wagon 440 auto I could get 14 mpg on the highway
Old Jul 5, 2012 | 07:14 AM
  #36
Nightmare's Avatar
im wondering this as well, i have a 7.2L 440 im putting in my roadrunner,and id like to keep my mpg in the teens.
my boy has a 9.0L 572 chevy BB in his 69 camaro and he told me he gets 4mpg, so i dont think bigger is better in some cases
Old Jul 5, 2012 | 09:07 AM
  #37
MrOldart2U's Avatar
Well the 77 Newport in town would get between 12-14mpg... hyway use was around 15.5. But that was after the lean burn delete I did.... Its geared with 2:91's i think... i know its in the 2:9x something range. But now car is fubared so its sidelined now... :/
Old Jul 10, 2012 | 11:20 AM
  #38
72sebring+'s Avatar
71 rr
had a bone stock 71 runner with a 383 automatic. only non-original part on the car was one size smaller carb. dont know what size???? original owner replaced it. said it was the
same brand carb only one size down. i used to drive the car from san diego to arizona to visit my dad. tires were 255/60 15. if i kept it under 60mph i would get right about 20 miles per gallon on premium. really! that was pretty flat terrain. so i could be very light on the throttle. i dont think the car could go much slower in 3rd gear. it was around 350 mile tirp.
my 66 mustang used to get over 20mpg with a jacobs ignition installed. but it quit working and now i have an msd installed and it only gets about 17-18 right now. but i did some work to the carb myself. 289 2 barrel auto.
i could sure tell the difference when that jacobs ignition was working. the car was faster and completely different throttle positions to attain the same speeds. it only worked for about 12 months though.
Old Aug 29, 2012 | 10:24 AM
  #39
minnmc's Avatar
An easy-to-live-with big-block that could run on pump gas and make way more ... with a goal of achieving better gas mileage than the small-block we took out.
Old Aug 31, 2012 | 07:43 AM
  #40
homebrood's Avatar
Talking
My 66 New Yorker gets around 9 to 10 per mile combined HWY/Town
I suppose on a trip I would get 10 to 12
Tom
Old Sep 1, 2012 | 03:41 AM
  #41
cork1958's Avatar
I've gotten 15.1, 17.2 and 15.4mpg on the 3 full tanks I've burned up since getting my 361 big block Plymouth Satellite, 3 weeks ago. All stock, all original, 2bbl, 3.23 rear end.
That 17.2 was a small trip up north from me, cruising at 55mph. About to make that trip again today and will have to fill up, so will have another tank burned up.
Edit:
Got 16.2 mpg's on that small trip mentioned above.
Old Sep 30, 2012 | 12:03 PM
  #42
Chryco Psycho's Avatar
I built a very efficient 512 / 440 , ported heads etc & it dynoed @ 398 Hp & 460 ft lbs at the tires on a mustang dyno & with 3.54 rear & 833OD we have squeezed 17.8 mpg on the highway ... best of everything !!
Old Mar 13, 2020 | 06:17 PM
  #43
Daniel Tishman's Avatar
Cummins 5.9 ram 2500 2wd
My big ram loaded or not gets 18-20 mpg anything less than that would be not acceptable. I like to drive not pump gas. Get a small block 6 speed.
Old Mar 13, 2020 | 06:26 PM
  #44
Then again that tuned 440 sounds close to my set up. My Cummins is so efficient its just built to run and run just keep the rest of it up and you're set. The point is if you engineer it right you might just get the best of all world's reliable, efficient and bad ***! I looked up this thread because the 440 is a cool engine but I figured it was a pig like the hemi but I guess not if set up right.
Old Mar 14, 2020 | 03:51 AM
  #45
I would suggest you start your own threed, this threed has been dead for eight years.👍
Old Mar 14, 2020 | 05:45 AM
  #46
Ram 2500 5.9 Cummins
Thanks for the suggestion but i like this one!
NeverEnoughAuto
Sep 12, 2014 06:17 AM
rr69half6bbl
Apr 12, 2011 11:10 PM
skatefast91
Oct 15, 2010 07:07 AM
Barfly
May 5, 2010 05:53 PM
ef8340
Sep 22, 2008 08:31 PM
