a body ball joints
Old Mar 9, 2012 | 04:46 PM
willysman69's Avatar
a body ball joints
Can u guys tell me how the upper ball joints come out of a 69 dart . Do they actually tread out or just pop out with a hammer. I soaked around the top with blaster and put a big pipe wrench to try and turn the top but could not. Do i need a torch Thanks fella's
Old Mar 9, 2012 | 04:52 PM
They are threaded. Right hand threads. Mancini Racing sells the special socket that will work great. Since they are old you can heat up the upper control arm. You can also try a huge chinese cresent wrench with a pipe cheater.
Old Mar 9, 2012 | 05:07 PM
Duster360's Avatar
I had to rent a ball joint installer/remover from advance auto for $100 for mine every other ball joint, tie rod, etc. Poped out with the ball join removal fork and a hammer. But I have one ball joint welded in from last owner not knowing how to work on a car so I need a new control arm. But I also have a newer car.
Old Mar 9, 2012 | 05:40 PM
They can be a "B" to get out. You need the special socket to remove them And a 1/2" impact helps. Just go easy as it is easy to strip the threads. Use some heat on the control arm.. If they are rusted ?? good luck !! use lots of PB Blaster
BUT This is a good time to update to the later ball joints / disk brakes ? and larger bolt pattern if you so desire
Lowers are a piece of cake !!
Old Mar 9, 2012 | 07:15 PM
What happens on those old threads is the get stripped when you remove the old ball Joint. Then when you put the new one in it won't tighten up. Then you tack it in with 4 or 5 small tacks. So maybe the last owner had this issue.
Old Mar 9, 2012 | 07:48 PM
Duster360's Avatar
Mines not tacked its welded completely around which Is what's frustraiting but over all the joint is still looking good for now just have to get a boot put on it and it will be 100%
Dodge Phoenix
Nov 3, 2011 10:02 PM
samuelcosmo76
Jun 28, 2011 01:47 PM
xjonathanx
Jun 21, 2011 09:23 PM
phil111260
Feb 3, 2011 05:17 PM
gihuff
Jun 26, 2009 04:15 PM
