Brake fluid
Old Feb 7, 2015 | 10:29 AM
Skynyrd's Avatar
Brake fluid
Wanting to go to a higher temperature fluid but master cylinder
has warning use only dot three.
The high temperature. stuff say it exceeds any dot. Why couldn't you use the higher temperature Stuff ? Thanks
Old Feb 7, 2015 | 02:02 PM
You can use Dot 4 or 5.1 with out a problem as far as I know.....
Old Feb 8, 2015 | 05:27 AM
Skynyrd's Avatar
Thanks, it is just a replacement m/c from AutoZone.
Tandem .
Old Feb 13, 2015 | 06:37 PM
Skynyrd's Avatar
I found dot 3 high temperature. Fluid from Wilwood. 550 or something like that. Should help protect the fluid.
cuda341
Sep 5, 2014 07:13 PM
bremereric
May 20, 2011 06:15 PM
gonn6d
Nov 9, 2009 02:40 AM
jar84203
Aug 28, 2009 03:49 AM
NewportLord
Jun 25, 2009 12:22 PM
