Brakes pull to the right??
It is a 2003 Dodge Stratus Gt
I have put new calibers and new drilled and slotted rotors and new brake pads even drained & filled master cylinder but once in a while it will pull to the right ?? Is it possible that the brake proportioning valve is hanging up???
Thank you
Thank you
The following 2 users liked this post by TVLynn:
Dartster 66 (09-13-2013),
RacerHog (09-13-2013)
And tire pressure. Swap tires left to right and see if the problem changes. "Wiggle the crap" out of stuff up there looking for looseness
Have someone work the pedal, pump a little out each left/ right bleeder, and "feel" for difference in flow. Line pounded flat by damage?
Twin 440s
09-19-2014 10:14 PM
Marc Greenleaf Jr
08-29-2011 04:47 PM
